Samsung LN-S3251D No Sound, sound options grayed out.
  • triplefour
    • May 2014
    • 1747
    subject line says it all. what can i do here? i already tried factory reset and it changed nothing.
    is this just a bad mainboard, and the software notices it so grays out the sound option?
    Don't fear the repair...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LN-S3251D No Sound, sound options grayed out.
    Is the Internal Mute set to ON? . Accessed via the On Screen Menu
    • triplefour
      • May 2014
      • 1747
      the option is grayed out, like all the other options in the sound menu except whether or not to play the startup and shutdown chime (melody) but of course no matter what thats set to i hear nothing
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        hear something if you plug in a set of head phones?
        • nomoresonys
          • 12331
          • U.S.
          Maybe try a firmware update/reapply?
          • nomoresonys
            • 12331
            • U.S.
            https://www.justanswer.com/tv-repair...iant-when.html
            There's a mediafire link there if you can't find firmware at samsung.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Have you looked in the service menu i think its display/info, menu, mute, power or Mute 182 power (tv is off) to enter the service menu on these tvs
              • freakaftr8
                • Oct 2012
                • 3743
                I would check to see if VCC is feeding into the audio processor. Maybe if notit's not, the tv is tricked into thinking there is no audio option present. What happens if you try to turn the volume control up-and-down do you see the bar show up with the volume?
                  09-07-2024, 05:50 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                  09-06-2024, 11:40 PM
