Fulty LG 60PB690V dark screen
  • perox
    • Mar 2018
    I got faulty plasma LG 60PB690V with no picture and no sound . Just click on with nothing on the screen. Also no signs of life on the main logic board (5V Dc present). Checked power supploy and voltage is as should be (205VDC, 55DC, 17V, etc.). Found no 18V comming from Y-sus to X-sus. Y-sus was repaired by professional and 18V Dc was fine. Picture came on and gone of in the split of the second and goes dark. Bought X-sus from Ebay (from broken screen TV) and no changes. Main logic control board LED is on and blinks in pattern: long, short, short pause, long, short, long pause. I couldn't find blink error codes on net for LG. Could be main AV board also faulty? Please, help.
    Thank you
  • perox
    • Mar 2018
    Re: Fulty LG 60PB690V dark screen
    Sorry. Instead of X-sus should be Z-sus. I tried with second hand Z-sus and picture is still dark
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • ipatch
      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
      by ipatch
      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
      08-24-2024, 02:36 PM
