Has anyone ever repaired a bad panel driver?
  • johniwad
    • Jan 2015
    • 23
    Re: Has anyone ever repaired a bad panel driver?
    From the looks of it both driver boards have the same components except the right one. The pictures are of two ics that are only on the right driver board. I couldn't find any datasheets.
    • johniwad
      • Jan 2015
      • 23
      Marked:
      Standby OFF: 8v
      Standby ON: 13v
      LED Driver Output: 195v/161v
      Actual Voltages:
      STB: 8.79v
      ON: 12.79v (all marked A13v pins)
      PS ON: 3.3v
      LED Driver Output: 171.5v
      T-Con: 12.53v
      • lookimback
        • Aug 2013
        • 1489
        Did you test all the MLCCs and resistors on the driver boards for shorts/opens?
        ------------signature starts here------------
        • johniwad
          • Jan 2015
          • 23
          I know it's unlikely for both panel driver boards to go bad so im thinking components that is not common with the other. The pictures are of two ic I found on the right driver that's not on the left. I am unable to find datasheet for these ics.
          • lookimback
            • Aug 2013
            • 1489
            I'm thinking the one is the edid eeprom. You wouldn't need a problem with both boards to have no picture on either side.
            • freakaftr8
              • Oct 2012
              • 3743
              I always thought that as well until I ran into the issue with the Sony XBR55X850B with the LG panel.... I believe now that IF a MLCC is shorted o n one side, it can affect the other.
              I also have a Sony XBR75X850C that had a shorted MLCC on the driver board, I fixed it but still fail to get a picture unless I force the tcon my jumping 12v to AVDD. I still 75% think it's a tcon problem.... Even thou I've replaced it with 5 different tcons and still no picture, but there's no voltage from the tcon out to the panel bu5 gets 12v in to tcon.
              • lookimback
                • Aug 2013
                • 1489
                That's what I meant. I think a shorted component on one affects the other through the T-Con. Maybe it causes something to go into protect mode, or maybe just sinks the voltage. In the case where you can't get a picture with either ribbon disconnected, perhaps there's something on one side which the other side needs and gets through the T-con. I've seen panels where you could disconnect one ribbon and get a half picture on the other side, but disconnect the other and just get a white screen on the connected side.
                • johniwad
                  • Jan 2015
                  • 23
                  I tried disconnecting ribbons one at time with no change. I will try testing MLCC and resistors tomorrow.
                  • lookimback
                    • Aug 2013
                    • 1489
                    Did you do it with the power off, and then turn it on after disconnecting? It usually won't work otherwise, and also hotswapping can damage the panel. I fried a 60" Sharp smart TV once by not turning it off before connecting the ribbon cables. Valuable lesson learned that day.
                    • johniwad
                      • Jan 2015
                      • 23
                      Yes I did that and I just checked for shorts I can't seem to find any. Not sure about those two ics though. I think I'm about to throw in the towel on this one. I really appreciate everyone's help and suggestions.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        You could always try applying 12 V to AVDD Before you give up to see if there is some kind of a picture there
                        • lookimback
                          • Aug 2013
                          • 1489
                          Also, it's possible the main board isn't sending any signal.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4542
                            • Italy - Milan
                            #33
                            It's not the right way to test a panel. 1st=test supply tensions on the tcon (attached and detached), 2nd=test those voltages on the panel's boards. If there are no tensions on tcon it's unuseful to do pass 2.
                            • lookimback
                              • Aug 2013
                              • 1489
                              I've had a couple occasions where I had another tv with the same LVDS pinout and put them back to back and plugged the LVDS cable from one to the other. Picture wasn't right, but it told me if I had a main board problem (no T-Con) or a panel problem.
                              • osrex
                                LED DRIVER KEEPS DYING
                                by osrex
                                Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                i have no datasheet at all for the LED lights, all i have is its length.
                                long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                05-05-2025, 03:36 PM
                              • howardc64
                                LG 49UJ6500 LCD panel lighter band that goes away
                                by howardc64
                                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                02-19-2023, 12:13 AM
                              • triplefour
                                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                by triplefour
                                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                tcon is built into mainboard.
                                Only one cable goes to panel boards.
                                there is a cable from one panel board to the other that links them.
                                cost cutting measure that results in us having harder time to diagnose.
                                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                07-28-2022, 07:59 PM
                              • Storyteller12
                                QN55Q60R Service Menu Panel Help
                                by Storyteller12
                                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                01-13-2024, 01:57 PM
                              • maneatingmonkey
                                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                by maneatingmonkey
                                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                03-27-2024, 07:17 AM
