Samsung LN52A750R1FXZA Turning on and off
  • powerblackout
    • Feb 2018
    • 109
    Re: Samsung LN52A750R1FXZA Turning on and off
    Nice, well you can test it in standby without turning it on, for the 160.
    The TV turns on as soon as i connect the power supply to the TV.
    I made a video of the process:
    https://youtu.be/0Z0mq7BCWU0
    The chimes sound, the backlight comes on, sits for ~10 seconds, then shuts off and repeats.
    • powerblackout
      • Feb 2018
      • 109
      I measured the caps. Most of them read fine, but two are weird. They're supposed to measure 1000uf but the meter is saying they are 4500. Guessing those are bad then lol?
        • 12330
        • U.S.
        #43
        n/a
          • 12330
          • U.S.
          #44
          Oh so no steady backlight then?
            • 12330
            • U.S.
            #45
            lol, was your meter set to capacitance?
              • 12330
              • U.S.
              #46
              Ok, lets try unplug inverter and see if it quits cycling, always unplug tv before unplug any boards just for safety so no errant voltage messes anything up. Careful inverter carries high voltage too.
              • freakaftr8
                • Oct 2012
                • 3743
                Usually if the tcon were at fault, when you removed the LVDS cable that goes from the main board, that flat white ribbon like I mentioned earlier , the TV would stay on if the tcon were at fault.
                So right now this is looking more or less like a main board failure.
                • powerblackout
                  • Feb 2018
                  • 109
                  Sorry, what is the inverter board on this, the two pcbs on the sides of the TV?
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Your inverter is fine you are not getting an image when the back lights come on. If your inverter or your bulbs behind the panel were at fault you would still receive an image on the screen after the back lights come on after the Samsung Chime.
                    I'm looking all over the Internet for a clear photo of your main board, can't find one, can you take a clear photo of both the front and back of your main board?
                    This may be a failure of C102 on mainboard if it has one.
                    • powerblackout
                      • Feb 2018
                      • 109
                      Are there another more ways to ensure it's the main board?
                        • 12330
                        • U.S.
                        #51
                        My bad, I read the other post wrong, so unplugging tcon made no difference=tcon probably ok.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Grab a hairdryer. Heat up the mainboard. All over it especially concentrating on the 2 processors and the various ram modules inside the white line area.
                          • powerblackout
                            • Feb 2018
                            • 109
                            Does anyone know if the various main board models for this TV are interchangable?
                            My part says: bn94-01708C
                            Part on ebay says it works with my model TV but is BN41-00995C on ebay.
                            Here's an ebay listing https://www.ebay.com/itm/Samsung-BN4...gAAOSwPpZaFCua
                              • 12330
                              • U.S.
                              #54
                              https://www.ebay.com/itm/Samsung-BN4...gAAOSwPpZaFCua took a quick look on ebay one there for 26 +9 shipping, always check all numbers to make sure you get a match.
                                Here is what SJ has about your board and the substitute board:
                                http://www.shopjimmy.com/samsung-bn9...a750r1fxza.htm
                                  • 12330
                                  • U.S.
                                  #56
                                  check lower right for interchange.
                                    • 12330
                                    • U.S.
                                    #57
                                    Appears to be a match.
                                      • 12330
                                      • U.S.
                                      #58
                                      Too bad you cant do a factory reset or a firmware reapply in this one, might not have helped tho.
                                      • cliff_hootarski
                                        • Jul 2006
                                        • 411
                                        PTS electronics has a "repair and return" for that board.
                                        I'd try to see if you have a C102 on the back side of the mainboard, as this cap has been known to cause power cycling.
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          It's probably a processor timeout issue. It's looking for a signal or certain function call out it's not receiving it so resets itself thinking that this is going to be the fix. A lot of times it can just be a BGA soldering problem on the processor ram modules that's why I mentioned to grab a hairdryer heating up the board up a little bit.
                                          C102 failure Doesn't allow some circuit voltages to come up for the processor to operate properly. More sometimes introduces crosstalk in the voltages
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
