Successful LCD panel repair XBR55X850B
  • freakaftr8
    • Oct 2012
    • 3743
    Picked up this TV yesterday. Original owner said screen went out. Rather vague but OK as long as I didn't see any cracks I said why not. Only 40 bucks. My 65 cost 2300 new! It's a 55" version of the 65" and I've had for 3 years running strong up on the wall.
    When turned on right side black left side white with faint vertical stripes.
    My 1st rule of measure was to pull all covers off to expose LCD source driver boards on the panel itself.
    This is after trying one ribbon at a time trick. Left side would show a faint picture right side remained black.
    Checked MLCC capacitors and found right side shorted. Look for the lowest resistance reading in found one reading .7 Ω where the others are reading 1.8 Ω. So I went ahead and removed it knowing that all these capacitors work in series. The bad capacitor was the 1st one nearest the ribbons that go into the source board from the tcon.
    Powered up and have perfect picture!
    Removal pics to come as soon as I can find my USB cord.
    • 12332
    • U.S.
    Re: Successful LCD panel repair XBR55X850B
    Nice fix Freak, thanks for sharing
      • 12332
      • U.S.
      So you got the low reading while in circuit or did you pull a leg?
        • 12332
        • U.S.
        Dam nice score, 55 3D Smart tv. There's a firmware update warning. https://esupport.sony.com/US/p/model...OC=3#/howtoTab
          • 12332
          • U.S.
          Prob. not a big deal, says Some TV features stopped working properly after installing a software update released in May 2016. - Fix Available!
          • freakaftr8
            • Oct 2012
            • 3743
            I got the low resistance reading in circuits. Remember to remove tcon ribbons 1st. I look for the lowest resistance reading on each of the 8 across the right. When you find the lowest resistance reading capacitor pull it cause that is usually the problem. Capacitors along source driver boards on panels should never have a low resistance reading. Not too sure why these things short out but it does happen.
            • freakaftr8
              • Oct 2012
              • 3743
              Nice! Everything after may 2016 is downgrading the tv. Typical...
              • freakaftr8
                • Oct 2012
                • 3743
                Thx for the warning! I probably won't be doing an update lol
                  • 12332
                  • U.S.
                  Great info. thanks.
                    • 12332
                    • U.S.
                    Makes me wonder what the hell is wrong with the people running sony.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Btw this is an LG built panel and tcon. Sony proprietary mainboard. The XBR75X850c had the same problem as well. That was a Samsung built panel. (S corp.) Which used to be a joint Sony/Samsung company sold primarily to Samsung Holdings a few years ago.
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • Takeatry
                        Yet another Samsung QLED Boot Loop
                        by Takeatry
                        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                        10-04-2024, 02:57 PM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • howardc64
                        LG 49UJ6500 LCD panel lighter band that goes away
                        by howardc64
                        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                        02-19-2023, 12:13 AM
                      • Storyteller12
                        QN55Q60R Service Menu Panel Help
                        by Storyteller12
                        I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                        I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                        I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                        the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                        01-13-2024, 01:57 PM
