Hitachi 42HDX99
  • dprit
    • Jul 2015
    • 49
    Hitachi 42HDX99
    Does anyone have a idea why there is a 2.25 inch black bar from top to bottom on the right side of the screen (As you are looking at the front of this plasma set)? Picture is fine otherwise. It is not the screen bezel. Any writing on the right side is cut off/missing into this black bar.
  • R_J
    • 9627
    Re: Hitachi 42HDX99
    Check the cable between the panel and the board below the black bar, but most likely the cof ic on the cable is bad and not repairable.
    • flibidy
      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
      by flibidy
      I have here a Magnum IA.100 which belongs to my parents.
      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
      What Ive done........
      01-01-2025, 01:26 PM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • bouny56
      Lenovo E15 Nm-c421 usb-c work only in one side
      by bouny56
      ​Hello
      Laptop E15 I5 10gen
      Mb nm-c421
      I have a problem with the usb-c power dc.
      The motherboard start only in one side of the usb-c
      Replace the usb-c port 2 times same problem
      With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
      Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
      Can the pd controler be the fault ? Or something else maybe ?
      Thx
      02-11-2025, 03:15 AM
    • wolf1976
      hitachi 50hk5600 problem with display
      by wolf1976
      hi
      i have the above tv and the display starts distorts the display at only in applications like you tube
      after and on the didital channels
      now without connect the antenna only the image of itsselfs tv i have the image i have in attach
      i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
      can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
      09-13-2025, 02:26 PM
