Ok, I'm not positive but it looks like per post 95, if the proper voltage isn't there on powersupply with inverter unplugged from it, then the problems on the powersupply?
Lol, I just watched the same video before checking this. Diode mode isn't working on my meter, but I followed a tutorial and tested the ac and dc and it seems fine. 123 a/c 169 dc
Ok cool, I guess the thing to do is keep tracing it out, til you find the bad component, if there is one.
Check will62's post a little bit ago, he helped fix one with a factory reset. It was a panasonic but it had some symptoms like it could have been a bad board or such.
That is not right, in standby the PFC Voltage boost converter is off so the Voltage measured between the two legs of the main filter cap should be around 160VDC, when PS-ON is present then it should be around 380VDC in typical Samsung and most TV that has active PFC circuit.
Please retest the Voltage between the two legs of the cap again.
https://www.youtube.com/watch?v=bK0qFueHopw be very careful, I would only do the reset, like he does and not change anything in there but if you cant see the menu then probably cant do it.
Ok,changed out my leads on my meter. Measured again. 165.0vdc off and 169.2
on. both caps. cp802 and cp803
Is the ON = 169.2V reading with PS-ON present? If PS-ON present then we have problem with the PFC circuit. But I thought you have 365V on the fuse next to the filter cap before in the earlier thread, that must have been an error then.
