Samsung UN40J6300AFXZA Main Board Repair
  • johniwad
    • Jan 2015
    • 23
    I know this Samsung UN40J6300AFXZA BN94-08247E main board is bad. Screen is black with sound and back lights but no picture. I replaced the T-Con board with no change. I cannot find schematics for this board. Bought a similar main board for a different Samsung TV thinking I could just swap out the flash/eeprom chips. I swapped eeprom chip but replacement board show no signs of life. Should I swap out eemc chip or could the problem be in the SDP1415 SOC? Any help or advice is greatly appreciated.
    Original Board: BN94-08247E
    Code: BN41 -02353A
    Mode: BN41 - 02353
    Replacement Board: BN41-02353A
    Code: BN41 -02353A
    Mode: BN41 - 02353
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    Re: Samsung UN40J6300AFXZA Main Board Repair
    Did you check the LVDS on the main board with on an oscilloscope? voltage checks on panel power etc?
    • johniwad
      • Jan 2015
      • 23
      I seem to have all the proper voltages and I did check LVDS with my oscilloscope and there is no signals from main board to T-Con. I was thinking maybe the SDP1415 SOC may have a few balls that has lifted or is partially faulty.
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        Yesterday, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
