LG 32LB1R - dont turn on
  • jimmiscom
    • 22
    • greece
    Good day
    i have a LG 32LB1R dont turn on. stand by led is steady (not blinking or flashing) but dont turn on.
    any idea what to check first ?
    if you have the schematic of the power supply would be very usefull
    (i only have schematic of the main board)
    tks
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 32LB1R - dont turn on
    Originally posted by jimmiscom
    Good day
    tks
    What power supply number is used in your tv this maybe be the correct Service manual
    • jimmiscom
      • 22
      • greece
      thank u. i have al ready the service manual of the main board im looking the power supply diagram (yp2632t)
      the strange is that i measured the standby 5v voltage and was ok (about 4.8v)
      then i pressed the power button and suddenly it turn on.
      i closed it after few minutes and tried to open again but didnt turn on this time.
      i measured again the standby and when i pressed the button again it turned on.
      so everytime that dont turn on and i take a measurement with the multimeter it turns on.
      something must be charged after the measurement.
      any ideas now ?
      • vinceroger69
        • Mar 2012
        • 6714
        any ideas now ?
        connection or solder connection on the pin your testing? maybe also worth checking the esr/uf rating on the capacitors on the power supply
        a quick read of this thread does suggest it might be a capacitor issue too so i would fully re cap the power supply
        https://quuq.org/forum/index.php?topic=6929.0
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • Noah Glasse
          LG 50PK590 - three clicks and steady red light, won't turn on.
          by Noah Glasse
          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
          02-24-2025, 07:23 AM
