LG 32LB1R - dont turn on
  • jimmiscom
    • 22
    • greece
    Good day
    i have a LG 32LB1R dont turn on. stand by led is steady (not blinking or flashing) but dont turn on.
    any idea what to check first ?
    if you have the schematic of the power supply would be very usefull
    (i only have schematic of the main board)
    tks
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LG 32LB1R - dont turn on
    Originally posted by jimmiscom
    Good day
    tks
    What power supply number is used in your tv this maybe be the correct Service manual
    • jimmiscom
      • 22
      • greece
      thank u. i have al ready the service manual of the main board im looking the power supply diagram (yp2632t)
      the strange is that i measured the standby 5v voltage and was ok (about 4.8v)
      then i pressed the power button and suddenly it turn on.
      i closed it after few minutes and tried to open again but didnt turn on this time.
      i measured again the standby and when i pressed the button again it turned on.
      so everytime that dont turn on and i take a measurement with the multimeter it turns on.
      something must be charged after the measurement.
      any ideas now ?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        any ideas now ?
        connection or solder connection on the pin your testing? maybe also worth checking the esr/uf rating on the capacitors on the power supply
        a quick read of this thread does suggest it might be a capacitor issue too so i would fully re cap the power supply
        https://quuq.org/forum/index.php?topic=6929.0
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • Noah Glasse
          LG 50PK590 - three clicks and steady red light, won't turn on.
          by Noah Glasse
          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
          02-24-2025, 07:23 AM
