Samsung PN50B650S1F clicks on plug-in with flashing voltages
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    #41
    Re: Samsung PN50B650S1F clicks on plug-in with flashing voltages
    Is that with the buffer boards detached?
    They call me......."threadkiller"
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      #42
      Okay I ohms tested the Vs on both x and y sustain boards. There are two Vs pins on each. Both Vs pins on the x and ysus read a very high level of resistance then go open.
      • freakaftr8
        • Oct 2012
        • 3743
        Good. Go ahead and reconnect both boards to the power supply. Then power up with PS on grounded only. Does power supply stay on?
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          #44
          Disconnect ribbon cable from main board? or just jumper with it hooked up?
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            #45
            I unplugged the ribbon cable for the main board, jumpered PS_ON to ground and the unit DID NOT power cycle! LED 2000 flashes once per second.
            Main board?
            • freakaftr8
              • Oct 2012
              • 3743
              Try the same procedure with VS grounded as well. If power supply still comes live check your VS voltage and VA voltage. If all looks well then yes main board is at fault..
              And yes all these procedures are with the cable disconnected from the mainboard. So yes you are doing it correctly
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                #47
                Ok I grounded Vs/STBY along with Ps/ground. Power supply remains live, Vs and Va voltage correct!
                Buddy, you walked me through that like Sherman went to the sea! Well done and thanks a whole lot for being so patient with an amateur, and the appreciation goes for everyone who stepped up and helped!
                Looks like all the reliable sources for main boards are all sold out right now. Are there any repair options available?
                Again...well done and thank you!
                • freakaftr8
                  • Oct 2012
                  • 3743
                  No problem man that's what we're here for! You could try heating up the main board with a hair dryer especially around the processor in see if the TV comes up. Could be something as simple as a bad soldering job underneath the main processor.
                  Could you post a clear picture of the front and back of the main board?
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #49
                    Interesting you should ask that. I just pulled the board and look what I found on the back of it.....
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      #50
                      And the front....
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        That dried creamy looking shit is normal believe it or not. I see a lot of Samsung boards like that. Should have no bearing or effect on the way it's acting. Those components underneath the main processor look rather toasted. I wouldn't be surprised to find out the main processor has some ball grid array bad contacts underneath.
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          #52
                          This?
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            #53
                            Bad soldering job on the processor.....ball grid array.....is this why one might "re-ball" a processor?
                            I have a heat gun....and nothing to lose.....so could I pull the heat sink off the processor, hit it with the heat gun on low and re-flow the balls out underneath?
                            If so I would need suggestions on how to get the heat sink/double sided tape? off without causing damage and pretty specific instructions on heating the chip up for the re-flow. If you or anyone knows of any video resources I tend to learn best this way.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              You could start by this hitting the area with the heat gun with the heat sync still on. Focus around processor and rectangular ram modules. Also heat up and V ram this is the rectangular module with the pins coming off the side there's probably about 25 pins on each side.
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                #55
                                How long should I heat it for, and how far away should I keep the heat gun from the chip/heat sink/components? Should I put something flat under it so the board doesn't sag?
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  #56
                                  I'm pretty sure that heat sink is going to have to come off. Can you tell me how to do that and put it back on? Simple as new tape and stick it on there?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    It's taped on just apply a little heat in gradually pull away. However you could try just heating the hell out of the board and powering it up and see if the cycling stops.
                                    Try heating up the NV ram module this is the rectangular one with the pins coming out the sides only smokes
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #58
                                      My mistake. It actually looks like a paste or glue of some sort holding it on. It's gray in color, kinda metallic looking and has a slight amount of flex to it, very slight. Should I heat it, remove the heat sink then remove the remaining glue?
                                      I'd bake this thing in the oven if I didn't think my food would taste like solder for a year!
                                      • slap_happy
                                        • Nov 2011
                                        • 46
                                        #59
                                        Check the two coils near the power connector on the main board for 3.3v.
                                        Something like (but also quite different from) done in this video:
                                        https://www.youtube.com/watch?v=Wawf68FPv9A
                                        or: https://www.youtube.com/watch?v=OuijG2RvfJ4
                                        There are other common main board problems that cause flashing led on '09 era samsung plasmas (when the power supply is good), but I've forgotten them. I think one of them involves the sound ic or some other small ic.
                                        The main cpu could be toast or have bga problems, but often with those you get flakey pic or int performance.
                                        BN94-02855 main boards are running pretty expensive on ebay right now. When looking for boards this old I examine the pics closely and read the story about the board to try to determine how many hours are on the board.
                                        • DXseekerMO
                                          • Feb 2018
                                          • 1119
                                          • US
                                          #60
                                          OK so I borrowed a toaster oven from a friend and baked the main board at 400dgrs for 20 minutes. By the time it was done It was the tenderest main board I've ever had! lol?
                                          Re-installed it in to the tv and still a no-go.
                                          So for now and until I find another TV for parts or a cheap main board I'll be setting this thing aside. If I make any head way on it or have any other news I'll update later. Thanks for helping me find the problem everyone and have a good one!
                                          • ngml
                                            Repair of an LG split AC system indoor unit PCB
                                            by ngml
                                            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                            This indicates an error in the communication between the outdoor and the indoor unit.
                                            The outdoor unit is fine, so the problem is the indoor PCB.
                                            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                            Does anybody have the schematics of this board,...
                                            02-01-2025, 12:55 PM
                                          • nobbnobb1
                                            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                            by nobbnobb1
                                            Hi guys,
                                            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                            02-03-2022, 11:14 AM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • GRANDGG
                                            LG 42lw4500 flashing red light , wight light , 2 clicks
                                            by GRANDGG
                                            Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                            05-09-2025, 12:27 PM
                                          • Gjackson
                                            Air-conditioning unit power supply failing to power up
                                            by Gjackson
                                            Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                            01-08-2022, 09:24 AM
