RCA 46 LED: is this a t-con problem? (with image)
  • rmcolejr
    • Feb 2018
    • 3
    Hello all. We've had this TV for a few years now, and one day I went to turn it on, and it came on with this gray hatch pattern. No strange noises, no storms or power issues, it didn't fall or get hit. The image does not seem to change at all. No OSM shows up, nor input menu, or channel indicator when changing channels. It just stays the same. I was going to order a t-con board for it, but I found this awesome forum and decided to ask you guys before using the parts-cannon method on it.
    Thanks for any help that you can give!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: RCA 46 LED: is this a t-con problem? (with image)
    T-CON problems usually display vertical lines and I think I do see some. However, The side TABs could be at fault also displaying the horizontal lines. Without photos of the internals, I could only speculate. If the T-CON Bd. is available and at a reasonable price, I would swap it out and give that a try.
    • freakaftr8
      • Oct 2012
      • 3743
      Disconnect tcon to panel one ribbon cable at a time. See if you that the right side or the left side works with either other side Disconnected
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Originally posted by freakaftr8
        disconnect tcon to panel one ribbon cable at a time. See if you that the right side or the left side works with either other side disconnected
        +1
        • jlode675
          • Jul 2013
          • usa
          defective panel
          • rimwall
            Sony KD-65x7500D - double image - Tcon or Panel?
            by rimwall
            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
            Today, 02:09 AM
          • jason123
            ASUS PG27V Rolling Image - TCON?
            by jason123
            Hi there,
            My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
            I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
            It does this even with the monitor not connected to a computer / graphics card....
            11-01-2025, 05:41 PM
          • jason123
            Hisense 65R6E3 double-image / horizontal strips - TCON?
            by jason123
            Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
            07-19-2025, 08:07 AM
          • Track4207
            Hisense H50N5300UK reboots when showing full red images
            by Track4207
            Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
            What happens:
            • TV appears to operate normally, for an indefinite amount of time until a problem image appears
            • The problem image is displayed very briefly, then the
            08-30-2023, 11:58 AM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
