Friend got me this set which displays what appears to be a good steady picture but has same images blinking in and out top and bottom and mostly red tinted by the look of it. Tried factory reset in normal menu but no change. Opened it up to find t-con lead goes straight to screen boards. Power board looks OK as does main board. Any suggestion on what and where to check welcome or is this a no go.
Voxson VLCD40CP good steady picture also blinking ones
Tags: None
Re: Voxson VLCD40CP good steady picture also blinking ones
Having pulled main and gave it a good look over put it back in and checked all voltages which were all ok and also did voltage regulators which again ok but as most likely cause would be tcon board I pulled the screen surrounds far enough apart to expose that long thin board which has two straps bonded to screen. Fiddling with those didn't result in any change to display. Tried prodding and flexing both tcon and maiboard but again no change. Measured a voltage regulator on tcon ZXMP 6A17 and the gate leg (left) was jumping around in voltage all over the place but often around 8v with next to nothing on middle leg and I think 12v on right side leg. When I went to check these again nothing came on screen as somehow I blew fuse on tcon which was passing 12v through OK. Have to try find a fuse now, meanwhile any thoughts appreciated.Attached Filesif you find these attachements useful please consider making a small donation to the site
Damn, another "tcon on panel" design. Check to make sure that regulator didn't short close in OHMS test before replacing that fuse.
That looks like a failed gate driving signal. If you replace the fuse back to the initial symptom, try some heat along the right and left side of the panel..Last edited by freakaftr8; 02-15-2018, 01:09 PM.Did I leave the soldering iron on?Comment
Couldn't find a fuse so swore a bit and bridged it instead. This led to no intro screen picture (or menu etc) but I know backlights are on and steady. However, voltage check now shows only 10.8v going to t-con and that gate still all over the place. Thanks freakaftr8 I downed tools on that one then to have "a drink and a think" plus got sidetracked selling a couple of sets to pay for my faux pas. Will come back fresh tomorrow and give it a whirl again.Comment
Lol ok I'll be here. Check voltage with panel disconnected and see if 12v comes back. If so, something happened to a voltage regulator or a PWM circuit on the panel. Try checking all diodes too.Did I leave the soldering iron on?Comment
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by riparoHi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
I attach a link to download the service manual, thank you for anyone who can help me
https://tel-spb.ru/download/?brand=P...0E_LA73.rar​ -
by domixHello i have 43pus6401/12.
After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
Any common issue?
Thanks... - Loading...
