Can a small crack kill the whole panel?
  • Gorrillasnot
    • Dec 2013
    • 316
    hello all,
    After repairing the LEDs on a 50" TV (Sharp LC-50LB370U) I managed to crack the LCD in the lower left corner as can be seen in the first pic @ post #67 seen here https://www.badcaps.net/forum/showpo...0&postcount=67.
    I have tried retesting all the voltages which were normal, and reseating the t-con cables, running with only 1 t-con cable connected at a time etc. but I cant get any picture to display at all on the screen.
    My question is could a small crack like that kill the whole panel?
    Is there anything I can try before scrapping the TV?
    thanks
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Can a small crack kill the whole panel?
    There are plenty of cracked screen that display colours/strips/pattern across the screen so I would have thought there would have seen something on the screen.
    • Gorrillasnot
      • Dec 2013
      • 316
      That's what I was thinking..I've seen screens with way worse cracks display at least something.
      I went back a double checked my voltages and all were the same except for 1. DIM = 0 standby and 3.2v power on and is now 2.7v after fixing LEDs.
      Also before the LEDs were fixed the black wires at -VLED2 and -VLED1 showed 0v powered on or off and now show 4.5v powered on.
      does this seem normal?
      thanks
      • Gorrillasnot
        • Dec 2013
        • 316
        does those voltages seem about right?
        maybe a bad t-con?
        thanks
          I can confirm that a small crack can kill an entire LCD panel because I've done it before, and all that was visible was a very very faint vertical banding pattern.
          • budwich
            • Jul 2015
            • 3097
            your "observations" are somewhat "thin". Are you saying that you get nothing as in no back lights, no white screen (one tcon panel connected)... ???? flashing codes???
            you likely need to go back to basics and verify / list all the voltages that are printed on the connectors of the boards.
            having said that, is it really worthwhile since the screen is cracked.
            • Gorrillasnot
              • Dec 2013
              • 316
              Sorry about that..to be more specific when the TV is first plugged in it has the red standby light, after pressing the power button the standby light blinks red 7 times then turns blue, the backlights do come on, but there is never any image or change in whats displayed on the screen..just a dark blank screen as seen in the pic below.
              Running with 1 ribbon cable disconnected on the t-con doesn't give a white screen or otherwise change what is being displayed. I've tried each side being disconnected (one side at a time) and nothing changes on the screen.
              Ive retested all the voltages and they all were within spec..the only difference between before and after fixing the LEDs is the connection labeled 1. DIM = 0 standby and 3.2v power on before fixing the LEDs and is now 2.7v powered on after fixing them.
              Also the -vled2 and -vled1 are now showing 4.5v powered on.
              It's probably not really worthwhile to get working, I just hate to give up.
              If I could get it going I thought I would use it in the garage.
              thanks
              • freakaftr8
                • Oct 2012
                • 3743
                I'm assuming you have checked to make sure the you have 12 V going to the tcon board? How about tcon outputs? See anything on the ribbon connections in excess of 20v?
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  done the same thing on a 50 inch led set. when installing the display back into frame I created a very small "chip" on edge of display - messed up set - garbage can. could not believe I did that !
                  When removing and installing display screen - be VERY careful & patient.
                  • budwich
                    • Jul 2015
                    • 3097
                    thanks for the extra info. You should list the voltages / pins that you have checked (designations) along with any readings as your "normal" may not be "normal". Further, have you tried any "forced on power up sequences" since it appears you have some form of error code... which have you tried determining what that might be / mean? it wouldn't happen to be 2-5 flashes... :-)
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4316
                      • Italy - Milan
                      I don't understand this thread, even if you succesful bring back an image, that will be damaged, you can get more selling good boards than selling an entire defective tv!
                      • budwich
                        • Jul 2015
                        • 3097
                        I don't understand your comment. IF the OP can't get some sort of display to happen with the set and he has no other way to determine if the cards are working correctly, selling them thereafter would be a bad thing for him and the buyer.
                        • Gorrillasnot
                          • Dec 2013
                          • 316
                          At CN9100
                          15.v = 0v (standby and power on)
                          12v = 11.8v
                          12v = 11.8v
                          12V_A 11.8v
                          GND
                          GND
                          PS_On = .12v standby and 3.7v power on
                          1. DIM = 0 standby and 2.7v power on
                          the LED connector on PSU
                          +VLED2 65.4v then spikes to 96.4v then goes back to 65.4v
                          +VLED1 same as above
                          -VLED2 0v standby 4.5v power on
                          -VLED1 same as above
                          I have tried the chanel down + input power up sequence and it didn't change anything.
                          I don't think the TV is giving an error code( i could be wrong) the front LED always blinked red 7 times before turning blue (same as when TV worked)
                          Depending on the damage if it was just that small area in the corner I figured I could use the TV out in the garage.
                          I wasnt looking to sell the TV..mainly just tinkering and trying to learn at this point.
                          thanks
                          • budwich
                            • Jul 2015
                            • 3097
                            have you checked any fuses on the tcon?
                            • Gorrillasnot
                              • Dec 2013
                              • 316
                              I checked the fuse F101 on the t-con and it showed .4ohm on 200ohm scale.
                              Is there more then 1 fuse on the t-con?
                              thanks
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Here's the deal. Yes the crack has hindered the gate driving of the panel, You're area on the bottom crack spot is right where the 1st gate drives the horizontal span of the panel and every other gate consecutively needs to drive with the hand off of the 1st section. Sense that section has been damaged 1st then there is no handshake and no passive information going to the next gate thus for yes this can wipe out the whole panel it is rare but it can happen
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Reminds me of this, thus, I try my best to not drop anything or bump anything with an LCD!
                                  https://www.badcaps.net/forum/showpo...6&postcount=58
                                  ASRock B550 PG Velocita
                                  Ryzen 9 "Vermeer" 5900X
                                  Arc A770 16 GB
                                  eVGA Supernova G3 750W
                                  Alienware AW3423DWF OLED
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4316
                                    • Italy - Milan
                                    I dont know if you done other errors, lets suppose of not, it's a simple equation, if a broken glass brokes the tcon it's not useful to fix it or change it, it will break again...
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      if the 15v isn't ever there, then it might be a problem. Based on my limit experience, that gets delivered to the panel.
                                      • Gorrillasnot
                                        • Dec 2013
                                        • 316
                                        i tested both sides of the t-con fuse and get 11.8v so its getting power. I don't know how else to test it.
                                        i havent tested the 15v after fixing the LEDs but before i fixed them and before damaging the LCD it has never showed any voltage.
                                        thanks
                                          HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                                          This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:44 PM
                                          HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 03:36 PM
                                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-12-2024, 03:28 PM
                                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
