Panasonic TC-P55ST30 Interpreting SU-SD tests
  • FastEddie52
    • 18
    I have a 2011 P55ST30 with a sold led power led that switches to 14 blinks when the power button is pushed again. I have checked all the power lines, Vsus, Vda and P15 and find no shorts. SC2 is Ok. I was testing SU and SD boards and I get the following resistance readings. On SU42-2 VFO I get 2.2 m. On SD42-6 5V_F I get 1.6m and on SD42-8 SCNR_PRO I get 1.6m. All other pins were open. Black probe was on floating ground screw.
    I saw a chart posted that had readings at some of the other pin locations. What does the lack of resistance indicate if anything?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic TC-P55ST30 Interpreting SU-SD tests
    If your meter has a continuity feature( meter beeps when touched together ) use it to test again. If you hear a beep, you have a short. Low resistance means short, but I just use the beep test.
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
    • Mnawar27
      Panasonic CF-H2AU24EF3 bios locked
      by Mnawar27
      Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
      I need help to remove it,
      thankyou all.
      SN; 2FKCA26876...
      11-16-2024, 08:00 AM
