Philips 19pfl3505d/f7 - No Power - Voltages drop
  • caphair
    • Nov 2011
    • 1249
    When first plugged into the wall the standby light glows white for a few seconds, then goes out.
    When the light is on all voltages are present, once the standby light goes off all the voltages drop to about half their values or more on some rails.
    To get the light to come on again it has to be unplugged from the wall for a while, if directly unplugged and plugged back in the voltages stay low. Any thoughts?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Philips 19pfl3505d/f7 - No Power - Voltages drop
    Unplug mainboard and monitor standby pin on power supply, see if the drop happens still.
    Could be a shorted output regulator on mainboard dragging the rails down
    • caphair
      • Nov 2011
      • 1249
      I don't see a standby pin anywhere? When I unplug main board all the voltages are low like what happens if main board plugged in and standby light goes off.
      Also I don't know how this tv functions when it's working properly. Not sure if the white light is present when the tv is turned on or if it's usually always on in standby
      • R_J
        • 9624
        service manual: https://www.electronica-pt.com/esque...ileinfo/25756/
        • caphair
          • Nov 2011
          • 1249
          Originally posted by R_J
          Thanks. I'm not seeing anything about standby power though? Has a few p-on voltages but nothing about standby power?
          • R_J
            • 9624
            This looks like an always on power supply, AL+3.3v is the standby for the main (micro etc.)
            • caphair
              • Nov 2011
              • 1249
              Ok then measuring that it is 3.3v all the time even when I get the white standby light and when it goes out.
              Also it stays at 3.3v with the mainboard disconnected
              • R_J
                • 9624
                I think P-ON-H1 is the power on line (page 61), then goes to (page 49) CN301-9
                • caphair
                  • Nov 2011
                  • 1249
                  Should I jumper 3.3v to that line with mainboard disconnected to see if the rest of the power supply comes on?
                  • R_J
                    • 9624
                    As you can see the circut is complicated, I think if cn301 is disconnected, 3.3 volts applied to pin 9 should turn on the voltages to their respective circuits, the power supply itself should already be on
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      What's your PFC doing? Check main filter capacitors at plugin then monitor for voltage drop..
                      • caphair
                        • Nov 2011
                        • 1249
                        Stays at 151v all the time. Never drops
                        • R_J
                          • 9624
                          If the power button is not turning on the tv It could be corrupt eeprom or bad connections on micro? (if it is bga)
                          There is no pfc circuit
                          Do you have all the supplies out of the transformer? ie c632 +31 C401 should have a negative voltage +15 volts on Q201 collector etc.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Don't think that can cause a voltage drop. 151v always means hv not coming up. Opto?
                            • caphair
                              • Nov 2011
                              • 1249
                              I have all the voltages that are labeled on the jumpers but they all drop to a half or lower once the white standby light goes out.
                              But it makes me wonder if the tv is powering itself on once plugged in then goes out. I'm not sure the normal behavior if there's usually a standby light or nothing until powered on, but pressing the power button does nothing.
                              The micro is a bga type. Should I try reflowing it?
                              • R_J
                                • 9624
                                I'm going by the schematic, and I don't see the jumper your talking about. there are voltages like INV+31 on D632 (K) and PANEL +15 they should be there all the time. are you saying they drop in half?
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  I'm going by the schematic, and I don't see the jumper your talking about. there are voltages like INV+31 on D632 (K) and PANEL +15 they should be there all the time. are you saying it drops in half?
                                  If you zoom in on the psu you'll see a bunch of jumpers, they're all labeled for the voltages etc. I've been measuring there
                                  And yes all the voltages either drop in half or more. For instance the 31v will be present until the white led goes out then it drops to 6v
                                  The only constant voltage seems to be the 3.3v always which never changes
                                  • R_J
                                    • 9624
                                    It's imposible to know where a jumper on the board is located in the schematic. So if the main power supply is being controled there is only one place that can be. They must be changing the voltage on IC601 optocoupler via Q633 with the P-ON-H2 line
                                    Going by the block diagram, P-ON-H1 & P-ON-H2 are controled by the micro. One of the lines controles 2 transistors Q3005 & Q3006 which seem to be on the main board.
                                    You could check those two lines and see how they change when power is applied and the light comes on
                                    Another line that seems to go in and out of a few different plugs is the KEY-IN1 line, thats the input from the keyboard/power switch, I would check and see if that line is changing when the power button is pressed, I would check it where it connects to the power supply cn102 then follow it through the other plug to the main board and then to the micro
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      Voltages when the white led is on (both drop to 0v when it goes out)
                                      P-ON-H1 = 3.3v
                                      P-ON-H2 = 1.5v
                                      Voltage present at all time (with or without white led)
                                      KEY-IN1 = 3.3v drops to 0v when pressed
                                      No continuity from the cn102 to cn301 though and 3.3v is not at cn301 where connects to mainboard even if mainboard disconnected still 0v at pin 29 of cn301. Can’t find if there’s anything in between the two connectors that would cause an open. Looking at the schematics am I right to say that KEY-IN1 becomes VCOM-PWM?
                                      Going by the service manual, it seems the white led is linked to P-ON +5 so it appears the set it auto turning on when first plugged in. Would this be normal operation? A power on test? Or something wrong with microcontroller?
                                      • R_J
                                        • 9624
                                        KEY-IN1 goes from CN102 (4) to CN302 (29) Then to CN3702 (29), R3703 (100ohm) then to IC3301 (AC5) [page 57]
                                        I think you mixed up CN3702 (pin29) KEY-IN1 with CN3701 (pin29) VCOM-PWM
                                        I don't know how "this tv" works, but sometimes they turn on the power supply at initial power on to make sure all voltages etc are there and ok, then turn it off again and wait for the power on to be pressed.
                                        • Thierry Wolffenbuttel
                                          Ps5 with bad standby voltages
                                          by Thierry Wolffenbuttel
                                          I have a few standby voltages that are 0, as seen in the picture. Is the Panasonic chip broken? In the picture I have all my voltages.
                                          04-08-2024, 08:04 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
                                        • Crystaleyes
                                          iMac A1224 PSU, 614-0421 - no standby voltages
                                          by Crystaleyes
                                          Hi chaps.
                                          Having recently picking up two dead 2008 iMacs, one is now working, however there is still one to repair.
                                          I was told that they both had failed power supplies, and seeing how I intend to crack SMPS repairs, it was a challenge not to ignored.
                                          Anyway, this PSU in question had already had someone having a pop at soldering.
                                          The current problem is (at the very least) in the primary side.
                                          Fuse is ok
                                          MOV is ok
                                          NTC is ok
                                          Bridge rectifier is ok (~380vDC)
                                          Fat filter cap is ok
                                          10-11-2021, 05:07 PM
                                        • zwerw3
                                          la-g07jp no standby voltages
                                          by zwerw3
                                          Hello. Please help. la-g07jp rev1.0 does not turn on. The 3 and 5 volt alarm goes up for 2 seconds and goes out. I opened the 3 and 5 volt power jumpers, removed the pu302, flashed the multimcontroller with different firmware, nothing helped. I noticed that on the u4104 the output is 1.5V, this voltage goes to the combined processor. Should there be such tension there?
                                          05-06-2024, 01:01 AM
