LC70LE747 sharp Aquos repair
  • Servicem4
    • 11
    • Deutschland
    I got a problem with my tv LC70LE747 sharp Aquos.*
    -most of the time the picture is/was perfect
    -sometimes the picture has distortions
    -distortions means flickering image, wandering lines. Refresh rate seems to be reduced heavily. See video link also. https://youtu.be/fd1vDcAkiBE
    -in the past month the distortions were concentrated in one quarter of the screen
    -recently it started to cover the whole screen
    -a tv restart cleared the problem until some weeks ago
    -now a restart is not enough, I have to wait some hours to get a clear picture again
    -one time I got a blinking error code* (power led). It was blink-1sec-blink-long pause-repeat.
    Can anybody please help which part I should try to replace first- or is it the panel ?
    Thanks in advance
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LC70LE747 sharp Aquos repair
    Plug in one ribbon cable at a time from tcon board to panel.. Theres most likely 4 ribbons, try right 2 at first, then left 2.
    See if one side is fine.
    • Servicem4
      • 11
      • Deutschland
      Thank you, will try it today
      • Servicem4
        • 11
        • Deutschland
        My tcon inkl got 2 cables, but I wasn't able to test it yesterday. Atm my tv is difficult to start, mostly I get the described blink code error. Anyone got a service manual for my model?
        • freakaftr8
          • Oct 2012
          • 3743
          OK this is why I want you to try disconnecting each of those ribbon cables at a time. That issue you're having looks in line with the problem that I believe the panel may have. As soon as you disconnect one of the ribbon cables the TV may not have a problem starting and the picture may look good on one side.
          This testing is going to tell me which gate driver has failed on the panel.
          You could try starting with the left side 1st looking at the back of the TV. That constant line just below center looks like the area where the gate has failed
          • freakaftr8
            • Oct 2012
            • 3743
            Here is a link to my original post on sharp 70" LCD panel failure you can read it and see what the eventual fix is for this kind of failure.
            https://www.badcaps.net/forum/showthread.php?t=49281
            Even though your TV is manufactured by sharp and not vizio it uses the same LCD panel.
            • Servicem4
              • 11
              • Deutschland
              Thanks freakaftr8, gonna try this too.
              But I think for me it's a power board failure.
              I looked into all similar service manual from sharp, and my blink code is always a voltage error at 13.5 v.
              Can someone give me help how to fix this ? Multimeter is here, I can solder basically ...
              • Servicem4
                • 11
                • Deutschland
                After further investigations the flat ribbon cable seems to be damaged.
                Any suggestions how to find replacement? There is no part number on it ....
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Can you post a picture of the faulty cable?
                  • Servicem4
                    • 11
                    • Deutschland
                    Is this sufficient?
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      You may find one on Ebay. It's called an LVDS cable.
                      • sefoster
                        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                        by sefoster
                        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                        11-20-2022, 09:29 AM
                      • jonah1024
                        Sharp Aquos LC-40UG7252E LCD TV burn in?
                        by jonah1024
                        Hello!
                        I'm a few days old into this TV screens repair universe so please bear with me.
                        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                        - I did a factory reset as well...
                        07-16-2024, 04:23 AM
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
