Panasonic TX-P42U30B strange behaviour and now dead
    My bedroom TV was doing something weird last night, and woke me up.
    Its relay was clicking on and off every 10 seconds, but the set was not turning on. It would function fine if turned on using the remote, and stopped when the power button on the side was used to turn off the set. When doing the relay cycling, the red light would blink as if it was picking up a remote control signal - but it would never actually turn on.
    Now, the TV is not turning on at all. The power light is locked green and the relay is cycling periodically. Pressing the power button on the remote causes the light to turn off, and then the set behaves as if it's completely switched off.
    I don't think this is a sustain IGBT failure, I suspect more likely main board related, unfortunately. :/ I do know that the 15V main supply is not turning on, because I added a fan to that rail (to keep SN board cool), and the fan is not heard to spin up. I will diagnose it when I have some more space to take apart.
    Both my Panasonic TVs have had strange failures recently, and they are both over five years old. It's really disappointing if this points to a consistent failure mode. The bedroom TV has less than 10,000 hours usage.
    Re: Panasonic TX-P42U30B strange behaviour and now dead
    The TV powered on, but it's becoming slow and freezing in menus and in the EPG.
    I think I know this fault - it's exactly the same as dead flash memory that I've encountered before on other products. When flash memory becomes bad, it can take some time to read sectors, or reads can fail altogether. This leads to the symptom of the TV crashing or taking ages to complete actions. The watchdog will sometimes step in, causing the Linux CPU to reboot.
    Sigh. This has been known about for years before this TV was made. But flash memory faults affect everything from TVs to Teslas so I guess the industry won't learn!
    • Battle1066
      • 14
      Well between our two sets we could do a case of fault finding by subitution if your in Leeds as I'm currently in Newcastle, if your interested?
      • freakaftr8
        • Oct 2012
        • 3743
        Degradation of silicon probably.
        This could be the new norm for Panasonic plasmas of this vintage. I have seen this twice myself. One was a th-42px77u and a tc-p50ut50
          Probably not, I'd rather not end up with two broken sets!
          I managed to fix my set temporarily by doing a factory reset. It might help fix the flash sector faults.
            Four days in and the TV is still working after this, no more strange behavour so it looks like it's fixed.
            • tw2005
              • Oct 2011
              • 6458
              Amazing
              • syaoran123
                • Jun 2014
                • 178
                The U series is terrible in these sets. Colours are washed out, even in a dark room.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  I think that was the cause of a Windows 7 installation failing real early on, before the first reboot, with error message (in a box) "Setup cannot install required files"(or similar)
                  (It looked like it completed extracting files though.)
                  (Because of a faulty "Gorilla Drive" USB stick drive) (Used to install Windows from)
                  (unless it was a shit solder joint...)
                  I hate silicon degradation! Reminds me that my pile of dog shit Pentium E2180 (poor man's Core 2 Duo "Conroe") probably had some of that! But, that's long gone now! It still worked fine at stock or a little OC, when I dumped it...
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    That certainly isn't true for the U30B. The TV has excellent picture quality and brightness, despite only using 200 watts from the wall. Excellent black levels and fairly minimal image retention too. It's a prime example of Panasonic's 2011-2013 NeoPDP tech which is very good.
                    • tw2005
                      • Oct 2011
                      • 6458
                      I actually find the image on th eU30 to be brighter and crisper in comparison to the upmarket st, gt and vt with the anti-glare coating.
                        Yeah I'm looking out for a U50B to replace the ST50B in the living room.
                        I don't use the 3D features on the ST and I think the brighter U50B would suit me well...ST50 is compromised on all except 3D mode (probably to improve panel lifetime).
                        • syaoran123
                          • Jun 2014
                          • 178
                          I just googled the reviews. It seems the 42 inch is not the same as the 50 inch.
                          Take a look:
                          https://www.cnet.com/au/products/pan...42u30a/review/
                          https://www.cnet.com/au/products/pan...50u30a/review/
                          I only had experience with the 50 inch. That could be the reason we're having mixed reviews.
                          • syaoran123
                            • Jun 2014
                            • 178
                            And that review on the 50 inch is in my opinion quite generous. It doesnt deserve a 7.4 rating. Should be lower than that, cos the image quality really is crappy. It's such a shame that this TV exists from a brand like Panasonic. I wouldnt even want to sell it to my customers.
                              Make sure you turn off CATS, as otherwise the picture is really bad.
                              The 50" will be dimmer per square metre, due to its larger size and comparatively similar power consumption, but I don't expect the picture quality itself to be much different, if at all.
                              • syaoran123
                                • Jun 2014
                                • 178
                                They call it eco mode over here. I always turn it off.
                                Had another p50u30a to repair and still produces the same washed out images.
                                I spotted another thread with TW saying the same thing.
                                https://www.badcaps.net/forum/showpo...7&postcount=12
                                • Rensiee
                                  Panasonic TH-50PX8EA Black screen, only relay clicks
                                  by Rensiee
                                  I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                  I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                  When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                  I have measured the voltage in the VSUS line, which...
                                  06-18-2024, 12:58 PM
                                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                  Found shorted diodes on main controller relays there are 3 of them that...
                                  01-07-2023, 05:43 PM
                                • CoinCoin88
                                  Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                  by CoinCoin88
                                  I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                  Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                  09-15-2025, 03:36 AM
                                • Andre Gilbert
                                  by Andre Gilbert
                                  11-20-2024, 08:52 PM
                                • valvashon
                                  Repair Success! Middle Atlantic UPS2200R-IP
                                  by valvashon
                                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                  02-06-2024, 12:54 PM
