Philips 32PFL3506/F7 no sound, no channels found
  • jose6326
    • May 2013
    • 707
    No sound but i do have picture
    I connected my laptop and a dvd player but no sound from the tv
    Also i checked the specs on this model and it has a digital tuner
    https://www.cnet.com/products/philip...3506-f7/specs/
    So i connected an antenna and did an auto channel program and it will not pick up any channels
    I checked the boards for any physical damage and none at all
    Should i just change the main board or what can i test?
    Will this board work for my model because i cant find the exact one
    https://www.ebay.com/itm/P-F-A91F6MP...edirect=mobile
    Thanks in advance
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 32PFL3506/F7 no sound, no channels found
    Do you have the voltages as printed on the circuit board especially around the tuner eg Tuner 5V ?
    • jose6326
      • May 2013
      • 707
      i will check today when i get home
      • aidanmo
        Philips 43PUS7506/12 - Loud blown out sound
        by aidanmo
        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
        I thought maybe the speakers got damaged, so I replaced them - no dice.
        • Using the internal speakers, it always happens.
        • Using the headphone jack, it never happens.
        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
        02-28-2025, 03:13 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • r2digital
        Harmon Kardon AVR340 no sound on 4 channels
        by r2digital
        Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
        03-09-2024, 01:33 PM
      • kotel studios
        Philips SAA7134 TV tuner card - requiring drivers and software
        by kotel studios
        Sorry if I posted this in the wrong forum.
        As mentioned in the title I'm looking for Philips SAA7134 TV tuner card driver and software. Sadly I couldn't find anything online. Maybe someone here has them?
        02-09-2025, 07:25 AM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
