Samsung led tv #UA32C4000PA with no backlight
  • playstation1200
    • 5
    • india
    hello badcapians!
    I have a samsung led tv model#UA32C4000PA with a power board model#BN44-00349A which I'm trying to repair.
    the tv starts normally. passed flashlite test for picture. sound ok. only issue is theres no backlight from the tv. overall visual inspection found nothing fried or burnt. all capacitors and other components look good.
    I tried to first check the power output from LED driver pins thats marked +led1. it shows a measurement of +85-89v while the -led pins shows 0. I tried to open the entire panel for checking the led's on the strip. all LED's seem to be fine. checked all the led's individually. the led strip is divided into 2 halves each containing 50leds,total 100.althought almost few led's towards the end of the strips look a bit darker than others but they do glow individually when 3v power is supplied to them through a battery. while diagnosting I found a small chip(possibly caled the pwm IC)with thermal protection over it was making a very suble noise like those which u hear from a laptop harddisk which is tring to access data(kirkirkirkirkirirkri!!!). i pressed the heatsink 3-4 times and suddenly the power on the +led pin bumped to 321v...after i connected the led's it immediately started the backlight and I got my backlight on again. but once i switched off the tv and tried to restart the same problem started again. now even after pressing that IC nothing is happening...the voltage is same 85-87v(both when led's r connected as well as when the led strips r disconnected). can someone throw some light on which part of the board could have gone defective. how to identify and troubleshoot the root cause.
    I've Attached an original reference pic of my powerboard. I'll try to upload the entire original pic of the powerboard and main board too.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung led tv #UA32C4000PA with no backlight
    Try soldering the pins on the IC. If that doesn't work look for cracks/break on the circuit board near the IC, and if that doesn't work direct replace the IC.
      This board is also known for bad solder joints, especially the legs of the transformers and power devices that have through hole rivets.
      The 85~87 V is the feeding Voltage to the Voltage boost converter circuits for driving the LED strings, it comes on when BL-ON is present, if it detect open circuit in the LED output or over current condition then the Boost converter will go into shutdown so the output at the LED+ will drop back down to 85V.
      • playstation1200
        • 5
        • india
        i tried to check the voltage on that ic. the voltage on pin 1 starts at (+-)190-200v and drops down to 0...the rest of the pins stays at 0.9v. I've attached an image of the actual board with real voltage output mentioned on some of the pins. plz have a look.
        • playstation1200
          • 5
          • india
          so exactly which part should i start checking from voltages or the circuit. coz i've checked all the leds in the string and all are ok.check the above post.i've attached a pic of the powerboard mentioning all the voltages im getting from the circuit.see if u can find anything. and why theres no voltage power from 2 of the resistors(i've marked them with thr zero voltages.checked the resistance of the pins,seems to be ok with 0.6ohm resitance)
            09-07-2024, 05:50 AM
          • C152Heavy
            by C152Heavy
            Summary for TL-DR readers:
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
          • Anooc7
            Samsung UN75NU6950 no backlight but leds works when checked individually!
            by Anooc7
            Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
            09-16-2021, 06:16 PM
          • ohren
            Samsung ue55nu7096u - no backlight - faulty LEDs?
            by ohren
            I'm looking at a Samsung model ue55nu7096u that I've only ever seen in a non-working condition, i.e. I don't know if the failure was progressive or instant.
            Symptoms
            No backlight at all — LCD and logic board are working normally. Resetting all settings and installing system updates has no effect.
            I tried reseating the connectors between PS and logic board, and PS and panel. No difference there.
            I could not find a service manual.
            Measurements when powered on
            Bulk cap: 388 V. Stable....
            04-04-2022, 02:58 PM
          • sansanpartida
            Samsung QE82Q70RAT no backlight
            by sansanpartida
            Hi everyone!
            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
            My issue: No backlight.
            Model: QE82Q70RAT
            Type No: QE82Q70RAT
            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
            So hopefully, I can fix this cheaper.
            05-22-2024, 06:56 AM
