Lg 42ln5300 led strips replace
  • crdz66
    • Nov 2012
    • 242
    Hello everyone.
    I have a lg tv model 42ln5300 with black screen but with sound.
    I noticed that the voltage going to led strips was too high according the specs.
    So i decided to check the led strips and i find one led burn out(1 of the 9) and one full line led strips out (no lights).
    So i bought two complete led strips (9 total each).
    So far was good.
    The problem start when i put everything back panels, boards,etc)
    as soon turn on the tv i see shortly light from led strips and turn off and now is back black again.
    My question guys is...
    Do you recommend everytime replace the all led strips and no just some??????
    This tv have 6 complete led strips and i replace just bad ones(2)
    i'm process of learning from my mystakes.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Lg 42ln5300 led strips replace
    Yes. Another LED on a strip was ready for failure. This has happened to me before. That's why when I get the LED array running, I leave it on for about an hour before I start reassembly. Just insurance that it's going to last.
      Did you verify that all the LEDs are on before putting the LCD panel back together? I usually let it run like that for at least 15 minutes. You also need to very that all the SMD connectors on the LED strip do not have bad soldering works, those connector are know for bad connection.
      • crdz66
        • Nov 2012
        • 242
        ok guys thanks.
        • Kingfreddie
          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
          by Kingfreddie
          Ok.. this is the story:
          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
          This is kinda how it looked, just that mine were at the bottom of the screen:
          09-11-2021, 01:57 AM
        • lmcancu
          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
          by lmcancu
          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
          Instead of putting it back together I decided to replace...
          04-01-2023, 01:11 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-12-2024, 02:30 PM
          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
