LG 42LH30 with weird issue
  • freakytiki4u
    Coolest Member
    • Aug 2009
    • 130
    I have an LG 42LH30 that has power, but no sound or menus. The backlight works. Here is the weird part. If I am facing the TV and I put a very slight pressure on the very top right hand corner of the TV bezel (push straight back towards the wall) the TV menus will pop on and the tv works perfectly. I took the back off the TV and looked at everything and pushed on everything with a plastic rod to test for loose wires, etc and can find nothing loose. I am assuming a bad panel (or cold solder joint somewhere) but this in an uneducated guess. I can actually rig the TV to work by using strong tape to slightly pull back towards the wall on the upper right hand corner, but I feel that is dangerous. Any suggestions, ideas or comments would be very welcomed and appreciated.
    *note* There are no bad caps (visual inspection only) and no burn or scorched areas on any boards or elsewhere. All cables are tightly connected and every screw I could find has been tightened but made no difference.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 42LH30 with weird issue
    Probably issue with tab bonds on the panel
    • freakaftr8
      • Oct 2012
      • 3743
      Agree. Bad tab bonding. Look up tab bonding repair in the forums or YouTube.
      • SuperJames
        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
        by SuperJames
        This one's a weird one, and still unsolved despite it having gone back to Dell once.
        Specs
        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
        Backstory
        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
        10-23-2023, 04:09 PM
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
      • lukkihapsi
        Asus Vivobook X515JA Weird Boot Issue
        by lukkihapsi
        Asus Vivobook X515JA Laptop
        Issue :
        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
        Tried :
        Cleaned inside for dust, applied fresh thermal paste. No Change!
        Removed keyboard, Trackpad, fingerprint sensor. No Change!
        Removed Internal SSD. No Change!
        Updated BIOS to latest version. No Change!
        Removed battery and pressing power button for 1 minute. No Change!
        Weird Part :
        Upon turning laptop ON, screen lights up - stays black,
        I...
        07-07-2025, 12:07 PM
      • Spider1211
        Weird but interesting issue with DELL 3542 (intel mb 13269-1)
        by Spider1211
        Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
        Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
        Backstory:
        Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
        Power supply draw:
        Voltage: 19.40V
        Amp draw: 0.006 - 0.007A
        Amp draw...
        04-07-2021, 03:21 PM
      • tommygun26
        Hp 6510b weird issue
        by tommygun26
        Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
        02-26-2023, 06:00 AM
