LG 42ld520 Main Board issues
  • Smoothjazz
    • Feb 2017
    • 13
    Been troubleshooting this LG tv set this morning.I get the LG startup screen..with no clock.. the screen suddenly goes away with only the back light
    lit up.Took DC voltages on the main power supply board which has the connection going to the main board and I am missing a couple 20VDC readings which
    is suppose to be on certain pins coming from the power supply board. Has anyone came across schematics for these power supply boards to try to troubleshoot
    voltages? The board has markings on what voltages are suppose to be at certain points.
    Re: LG 42ld520 Main Board issues
    We need pictures of the whole back side of the TV showing all the board.
    We also need the Voltage reading of the connector on the power supply board end that goes to the main board when TV is OFF and when TV is turned on, you MUST out down the pin name for each pin and follow by the Voltage readings for each pin.
    • Smoothjazz
      • Feb 2017
      • 13
      Will do
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
