Sharp LC-60E79U - 2 Green, 1 blink - 1 Green 1 blink
  • SolderMaster
    • Dec 2013
    • 53
    Re: Sharp LC-60E79U - 2 Green, 1 blink - 1 Green 1 blink
    Installing all the parts from Shop Jimmy fixed the problem... on that set.
    I have another set, same exact set. Replaced all the parts from SJ for the power supply, but I need to pick up some more optos. Will report back when those come in.
    • SolderMaster
      • Dec 2013
      • 53
      Side note on this 2nd set...
      Besides the set turning off and flashing the DET_10V failure (Power 2x, OPC 1x), the backlight tends to flicker. I wonder if this is a side effect of the DET_10V being missing or intermittent. When I replaced all of the parts from the Shop Jimmy kit, I reset the TV to factory. Just curious if the flicker is caused by the missing 10V.
      • SolderMaster
        • Dec 2013
        • 53
        After replacing the 6 Optos, and pulling the set out of fault using Vol -, Ch +, PWR, the set then went into a different fault code. Power 2 times, OPC 3 times = Det_6V failure. Some online searching says the 6V comes from the main. Does anyone know which part on the main generates that?
        Board # DUNTKF282WE19/ (A) FM19 X1
        Maybe I can replace the bad component and have a spare main.
        • Anzio
          • Sep 2012
          • 10
          I'm getting the same blinking light error. Did you find out what part on the main generated the Det_6V failure?
          -Anzio
