samsung ps51d7000 restart problem
  • dj01fad
    • Sep 2014
    • 92
    • romania
    hello.
    I have a samsung ps51d7000 that when I pug in it starts, displays logo and then displays the imput label (hdmi 4 in my case), and after 2-3 seconds it restarts. It doesn't respond to the touch keyboard or to the remote (the led is flashing when I touch the keyboard but does not respond to source, volume or pw off). can it be the nand flash? i'll try to put some signal on hdmi4 to see if it will produce an image or sound.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: samsung ps51d7000 restart problem
    Heat up the ICs that have the labels on them on the board. Try heating up the board with a hairdryer. If that does not work, could be the typical C102 10v 47uf problem.
    • dj01fad
      • Sep 2014
      • 92
      • romania
      I don't know about that typical problem. Can you tell me more? Should I replace tat C102 first?
      Thanks.
        Basically the ICs on this set can fail, heating them up can briefly allow them to work which can assist in the diagnosis.
        Not sure about the typical problem, Freak might be referring to the A550's problem with a tantalum capacitor, I don't think it affects your set.
        • dj01fad
          • Sep 2014
          • 92
          • romania
          OK then, I'll heat the board as soon as I get home.
          Someone from a samsung repair shop told me it's about the NAND flash. BUT, he told me that if only the logo appears and then restarts it's a NAND problem; on my set appears the logo, and the source box and after 3 seconds it restarts...
            It could still be a NAND issue
            • dj01fad
              • Sep 2014
              • 92
              • romania
              I have no changes when heating. I guess it remains the NAND.
              I found another thread here:
              https://www.badcaps.net/forum/showthread.php?p=659071
              now I'll try to freeze it to see how things will go.
              • Nick's Tvs
                • Jan 2014
                • 621
                This board commonly fails due to nand problems. You most definitely have a bad nand.
                There unfortunately are no more boards available for this model online. If you have the solder skills to replace the Nand itself, there are some people that sell them on eBay but they don't offer much of a warranty on those.
                If you do not have the soldering skills to replace those, there are services available such as the one linked below:
                https://www.ebay.com/itm/Samsung-Mai...0AAOSwol5Y0aoj
                Good luck.
                • dj01fad
                  • Sep 2014
                  • 92
                  • romania
                  I have the skills and the tools, but I don't have the chip and a programmer. I found someone here in Romania that can send me a new programmed chip for 20-25 euros and I think I'll go for it.
                  • Nick's Tvs
                    • Jan 2014
                    • 621
                    The chips for sale on eBay are preprogrammed and ready to go.
                      09-07-2024, 05:50 AM
                    • VikramB
                      Samsung QN55LS03 | The Frame TV | Weird power cycle and restart problem
                      by VikramB
                      First thread here on this forum, excuse me if I miss something in my first post.
                      I have the 55” variant of the Frame TV which is essentially a QLED tv. There's a weird problem where it would keep on restarting on its own. Funny thing is it might work perfectly for couple of days and then decides to go down the restart route. A few pointers:
                      1. If I let the TV sit idle for a day, for the very first time it boots after that time period it usually keeps working for 5 minutes before restarting. After that it restarts every 5 seconds.
                      2. I've tried the tape method and...
                      03-17-2023, 02:56 PM
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                    • alro7779
                      Samsung UN55MU6103F video problem; has colored stripes on the display
                      by alro7779
                      Hello, everyone!
                      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                      09-27-2025, 11:29 PM
                    • PL456
                      Samsung Np350V5C power on, restart 11 times before shutting down. UMA problem ?
                      by PL456
                      Someone gave me a motherboard and I am trying to repair it.
                      It comes from a Samsung Np350V5C laptop.
                      Motherboard model : QCLA4 LA-8861P REV 2.0 with a Celeron processor (for testing) and 1*2gb of ram.
                      One coil is missing (PL703) on this motherboard. Someone tried to enable UMA.
                      Problem : each time I power on this motherboard, the motherboard is ON 6 seconds before restarting by herself without shutting down... 11 restarts before shutting down.
                      The start up button works well, I tried it with another motherboard,...
                      06-09-2020, 02:58 PM
