PANASONIC THP42U20A main board issues
  • chrismurphy
    • May 2014
    • 251
    • australia
    I have this main board issue with this panasonic tv
    The TV powers up with steady green light no blinks , but no screen activity , all voltages on SC and SS boards are ok
    suspected the main board , so i reflowed both chips on the board and now i get screen ok and picture ok no issues , but no sound . When i press the volume up button the TV shuts down . Any ideas ??
  • happyade123
    • Feb 2015
    • 92
    Re: PANASONIC THP42U20A main board issues
    Maybe leakage in the front panel buttons. Try disconnecting it and turn on and do volume up with remote . I know you probably know a lot more then me but just a suggestion Chris.
    • R_J
      • Jun 2012
      • 9588
      Check that the speaker wires are not pinched or touching the chassis somewhere, you may have a problem with the audio output chip.
      Do you have the schematic? Check sos signal on D2014 or `C' of Q2301, does it change when vol up is pressed
      Do you have s_15v on L2301 or L2302
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
