PANASONIC THP42U20A main board issues
  • chrismurphy
    • May 2014
    • 251
    • australia
    I have this main board issue with this panasonic tv
    The TV powers up with steady green light no blinks , but no screen activity , all voltages on SC and SS boards are ok
    suspected the main board , so i reflowed both chips on the board and now i get screen ok and picture ok no issues , but no sound . When i press the volume up button the TV shuts down . Any ideas ??
  • happyade123
    • Feb 2015
    • 92
    Re: PANASONIC THP42U20A main board issues
    Maybe leakage in the front panel buttons. Try disconnecting it and turn on and do volume up with remote . I know you probably know a lot more then me but just a suggestion Chris.
    • R_J
      • 9624
      Check that the speaker wires are not pinched or touching the chassis somewhere, you may have a problem with the audio output chip.
      Do you have the schematic? Check sos signal on D2014 or `C' of Q2301, does it change when vol up is pressed
      Do you have s_15v on L2301 or L2302
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
