LG 60PZ950S - No Sound , No Picture
  • Piotr07
    • Oct 2015
    • 17
    • Poland
    Story of the repair: TV had some cold solders of coils on the Z-SUS , the board has been resoldered but after mounting the board I forgot to tighten all scews . When I power on the TV, I found some overcurrent on the Z-SUS , of course it was because of my mistake. Z-SUS board has been checked and any faults, the Y-SUS ans PSU also works correctly.
    The problem is on the Main , because TV wakes up from the STBY but no voltages M5/Va/Vs or Z/Y-SUS boards. The display works correctly on the AutoTest(autonomous mode) - of course, the Main is unplugged on this test. So, the PSU+YSUS/ZSUS should be OK when the display works on the AutoTest.
    I suppose that the Main has some protect mode(after overcurrent error), then does not start all voltages(M5/Va/Vs) .
    Do you know how to get into Service/No protect/ mode on this plasma TV chassis PD12C / PD12A . I think should be some service mode that the overcurrent faults can be removed.
    Or have you some dumps of the SPI/EPROM for this Mainboard EAX63525103 for 60PZ950S or 50PZ950 ?
    Greetings from Poland
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 60PZ950S - No Sound , No Picture
    I wouldn't suspect main board at fault at 1st I would try disconnecting ysus or zsus power connector and see if power supply rails come up.
    • Piotr07
      • Oct 2015
      • 17
      • Poland
      Please look again at my description, I was writing that the display works OK on SelfTest Mode so the SUS boards should be OK .
      • freakaftr8
        • Oct 2012
        • 3743
        Right. Want at i meant is you mentioned overcurrent on x sus. Something senses this as a fault. If mainboard will not power the ps_on then maybe you should look at an overcurrent issue in zsus by disconnecting it out of circuit then see if mainboard trips overcurrent.
        But I believe overcurrent is handles solely on power supply. So I suppose it could be a main fault as well. What are your ps_on and error det pins doing to mainboard?
        • Nick's Tvs
          • Jan 2014
          • 621
          If you have the test pattern show up properly then indeed it is a bad main. It would be cracked solder joints on the BGA chip. You would need to get the Main board reworked/reballed.
          https://www.nickstvs.com/store/p1363/EBT61582702
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
