LG 60PZ750 Dim, Spotty Picture, No Audio
  • beeser
    • Nov 2017
    Hello everyone!
    I have an LG 60PZ750 with some sort of strange problem(s). It turns on OK, but the picture is dim and spotty; about 40% of the screen is black. Also, there's no audio. I can pull up menus and was able to scan for the local broadcast channels. Unplugging the main power cable to the ZSUS board has no effect on the picture or audio. Pressing the volume up/down buttons makes the blue LED flash at the power button, but there's no other effect. I can't see any volume level display on the screen, though it may be coming up in a section of the screen that is blacked out.
    The VS is at 200 VDC, the VA at 55 VDC. The 5 V is reading 5.2 VDC. I am getting 200 V at both sides of the fuse on the ZSUS board.
    Any ideas on where to go from here? Thanks!
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: LG 60PZ750 Dim, Spotty Picture, No Audio
    pic of display, pics of boards would help
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • IAmOrion
      LG55UB850V no picture or audio, just flashing LED's help please?
      by IAmOrion
      Hi members, I came across this forum when searching a fault on my LG 55UB850V TV.
      Rather than hi-jack another members post/thread I thought I should start my own even though it's an almost identical issue.
      The thread I refer to can be found here:
      https://www.badcaps.net/forum/troubl...-s-help-please
      My boards are the same, and my issue it the same. I have NO Picture and NO Sound. Nothing. When first turning on the TV at the...
      01-28-2024, 06:50 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • WayOfTheRoad
      Vizio D55x-g1 (55" 4K, no backlight, has Audio and picture)
      by WayOfTheRoad
      Hello, everyone. A neighbor was throwing this TV away for "not turning on" so I asked for it and they gave it to me for free since Vizio gave them a new TV under warranty.
      I'm pretty proficient with electronics in general but this is the first TV I've ever tried to fix. I strongly suspect bad LED lights but figured I'd post some info and see if those of you more experienced with TVs can confirm my suspicion before I move forward. Some photos and measurements below:
      The power supply only has two outputs, one output cable going to the main board and the other...
      03-31-2022, 12:22 AM
