Bypass power switch
  • kthorpe88
    • Nov 2017
    • 32
    Bypass power switch
    Hello all,
    I have a sanyo fw65d25t that I picked up from someone who knows how a screw driver works. He said the picture just would take longer and longer to come on and then one day it stopped. Well he tried to look at and managed to get the back cover off and wreck the power switch button.
    So the indicator light comes on when its plugged in, I can't get it to turn on with a universal remote. He did say the back-light still worked just no picture. I'm wondering if their is a way to solder some jumper wires some place to turn it on with a switch?
    Or do I have another issue? I did check all the caps and voltage regs. The voltage reg on the FRC board that is 1117a does not have conductivity to ground at all on any of the 3 pins? Nor does the top tab/pin.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Bypass power switch
    Unfortunately, no. jumping out the switch won't force it to turn on, the CPU needs a whole sequence of events to startup.
    Follow the white rabbit.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Fixing the switch is not going to fix the problem. Since the switch was broken taking it apart to find out why it doesn't work.
      Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
      Format:
      Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
      1 - XXXXXXX - XXv - XXXv
      2 - XXXXXXX - XXXv - XXXv
      3 - XXXXXXX - XXXv - XXXv
      4 - etc.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        If the switch is an open/close type switch, there will be two (2) contacts that can be permanently bridged to put the switch in the closed position. However. if it is a momentary type micro-switch, then NO you can't put a permanent bridge but can use a temporary bridge to momentarily close the switch to trigger the power ON mode.
        • kthorpe88
          • Nov 2017
          • 32
          Ok so in picture 1 is the IR&LED CON10 and the Key CN6. The pin voltages are as follows.
          *PIC1
          *CN10 goes to IR&LED board
          L to R
          3.2v, 3.2v
          3.3v, 3.2v
          GND
          NC - 5.2v
          5.2v, 5.2v
          *CN6 Key
          (Goes to power button asm that the other guy wrecked)
          L to R
          3.2v, 3.2v
          3.3v, 3.2v
          NC - 5.2v
          5.2v, 5.2v
          *Pic 2
          *the first red connector (CN5 AMP PWR)
          L to R
          VR PWR, 12v
          VR PWR, 12v
          GND
          GND
          *Second red connector
          L to R
          55v
          5.2v
          GND
          *Big white connector (CN2 Main PWR)
          L to R
          12v
          GND
          5.2v
          5.2v
          5.2v
          5.2v
          GND
          GND
          4.8v
          5.2v
          *Pic 3
          *CN3
          GND
          GND
          GND
          GND
          LVCC - 12v
          HVCC - 55v?
          HVCC - 55v?
          HVCC - 55v?
          *Pic 4
          *CN4
          GND
          GND
          V PWR - 12v
          V PWR - 12v
          *CN1
          VR PWR - 12V
          VR PWR - 12V
          GND
          GND
          GND
          5.2V - 5.2V
          5.2V - 5.2V
          VSTB - 5.2V
          PWON - 4.8V
          5.2V - 5.2V
          5.2V - 5.2V
          GND
          GND
          *PIC 6
          Power supply
          *PIC 7
          Key/PWR button asm
          Other pics are just of all the boards.
          Hope this helps and gives some insight.
          • Powderfanupnorf
            Dell AL440LX power on switch circuit help required
            by Powderfanupnorf
            Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
            So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
            My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
            06-24-2024, 01:24 PM
          • grimacelord
            NEC TurboExpress On/Off Power Switch Replacement Help
            by grimacelord
            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
            11-09-2023, 09:49 AM
            09-06-2024, 05:59 AM
          • shovenose
            Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
            by shovenose
            Got this one for free because, well, it no worky.
            A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
            Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
            08-11-2021, 01:26 PM
