I have a Philips 50' TV that has a solid white screen. I have changed the main board, thinking that was the problem since the menu button works. Nothing changed so I changed the interconnect board and still the white screen. Any help would be greatly appreciated.
Philips Plasma 50PFP5332D/37
Re: Philips Plasma 50PFP5332D/37
Measure and compare on the label the following voltages to see how far off they are from what they should be:
Va, Vs, Vscan and Ve -
sorry for the late reply, been a crazy week. Im not really sure how to do that. I bought a multimeter because i knew that i would need one to fix it but not really sure how to check those. also, i dont know if this makes a difference but i tested the AV hookups and they work. it seems to be just the hdmi that doesnt work.Comment
by celiabrownHello guys,
My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
Can someone has any symptom like this ?
Thanks​05-09-2024, 10:56 PM -
by SharpaHello,
I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
The symptoms when bought: Philips logo appears then tv turns off
Things tried so far:
1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen... -
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... - Loading...
