Zenith Z42PJ240 no power
  • freelancenoob
    • Oct 2017
    • 77
    Tv was a dumpster find. Powered on and worked. Took home and it powered on again. Now it gets no power at all. No stand by light. I don't like the power button as its touch sensitive (no actual button). Is there a way to bypass the switch to turn the unit on?
    Anyway I checked all the fuses and all are good.
    Where do I go from here?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Zenith Z42PJ240 no power
    Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
    Format:
    Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
    1 - XXXXXXX - XXv - XXXv
    2 - XXXXXXX - XXXv - XXXv
    3 - XXXXXXX - XXXv - XXXv
    4 - etc.
    • freelancenoob
      • Oct 2017
      • 77
      Ok this is odd. Before I plugged in the unit I decided to just double check all grounding screws and make sure they were tight. After that was done I plugged in the tv. Power supply board made a click noise like a relay tripped. Standby light came on and I was able to turn the tv on. Turned it off and on a couple times no problem. I then pulled the power plug. Once I plugged it back in the tv was dead again. No click noise from the psu.
      In standby i got 3.5v from the standby pin. nothing from anything else on that header. After turning on the tv I got 17v from the 17v pin and i got 5v from the 5v pin and standby went to 5.2v. After unplugging the tv and plugging it back in I get nothing on standby. I do have 119v going to the input plug on the board though.
      • CapLeaker
        Leaking Member
        • 8153
        When the TV doesn't want to turn on, check the STBY voltage that goes to the main board. Also check for cold solder joints. I would investigate the STBY voltage circuit. Maybe there is a bad cap or a crack or something...
        You also can try heating the board with a hair dryer, etc.
        • freelancenoob
          • Oct 2017
          • 77
          When the tv doesn't have a standby light and it will not turn on I checked and I get no voltage.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Maybe push around on board with nonconductive tool while plugged in and see if anything changes
            • freelancenoob
              • Oct 2017
              • 77
              Poked and prodded around the board and no change. I did however unplug the main board from the ps board and i could get the relays to click again like it was turning on the tv. Unplug the tv and nothing. So I plug back in the mainboard and as soon as i plug in the mainboard with the power unhooked the relay clicks again.
              • CapLeaker
                Leaking Member
                • 8153
                so is stby voltage there on the PSU with the main board disconnected?
                • freelancenoob
                  • Oct 2017
                  • 77
                  correct
                  • freelancenoob
                    • Oct 2017
                    • 77
                    I grabbed a manual from this site
                    Below is the method it shows for testing power on failure.
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
