Pioneer Kuro PDP-LX5090 buzzing and crackling
  • tn245
    • Oct 2013
    • 530
    Re: Pioneer Kuro PDP-LX5090 buzzing and crackling
    You need to take off the front plastic bezel, and then the top edge of the metal frame that overlaps the panel. The EMI strip is attached inside the frame wedged between it and the glass panel. Be gentle with the panel!
    • Matcat
      • Feb 2018
      • 8
      im having trouble taking the front bezel off, the clips on the top are hard to release. thanks
      • tn245
        • Oct 2013
        • 530
        Remove the four screws/plugs along the bottom edge of the bezel plus two long screws that go through the back of the TV into the bezel at either end of the TV (prob already removed if back is off). Then you have to hinge the whole bezel up from the bottom to about 30 degrees and it will come off the clips at the top. I'm assuming it's the same as the 9G models I've worked on. Otherwise if you can get the service manual it should have instructions.
        • Matcat
          • Feb 2018
          • 8
          how do the clips come out, do i just pull them straight out? i dont want to break anything.
          • tn245
            • Oct 2013
            • 530
            The ones along the bottom? Unscrew the screws maybe half way and then pull the screw to pull the little plug out with it. The ones on the top should release easily once the bezel is lifted to the required angle.
            • Matcat
              • Feb 2018
              • 8
              when i pull off the metal frame on all sides there is no crackling sound and there is way less buzz. emi strip doesnt look degraded but does look flattened out a bit (never done this before)does that mean it needs new emi strip?is it the same strip you linked? thanks
              • tn245
                • Oct 2013
                • 530
                Probably yes. Without the frame there is nothing to arc to. On mine the foam inside the strip was obviously deteriorated and the strip looked hollow is how I would describe it. But also you can take a multimeter on continuity/diode/ohms mode and measure between the surface of the strip and the metal frame at various points. You should get a beep or low ohms all the way along. If not it's not conducting well and should be replaced.
                • Matcat
                  • Feb 2018
                  • 8
                  most of the strips are hollow, if i push down hard enough i get conductivity
                  • tn245
                    • Oct 2013
                    • 530
                    Definitely replace them.
                    • Matcat
                      • Feb 2018
                      • 8
                      ok received the strips they are the same ones you linked.
                      how do i apply them? they are 30 cm long and they are not cut straight.
                      do i cut them straight? do i overlap them so there are no gaps?
                      thanks
                      • tn245
                        • Oct 2013
                        • 530
                        You can cut the ends straight so they meet a bit more flush but I wouldn't overlap as it would end up too thick. Just try to get them to meet up nice and close without a gap. It's not too difficult.
                        • Matcat
                          • Feb 2018
                          • 8
                          ok replaced the strips and put back together the tv
                          the static sound has completely gone. Thank-you
                          It still buzzes fairly loudly, seems to be coming from the coils at the back of the unit, is there any solution for this?
                          • tn245
                            • Oct 2013
                            • 530
                            Yup. As I mentioned earlier in the thread, it seems some just do buzz more than others. One I had later on had the EMI strips in perfect condition but was louder than the one I replaced them on. If you read through you'll see I did dunk the vsus transformer in varnish before I figured out the strips were bad which may have contributed a little to quietening that one. I guess some of us were hoping this would be a magic solution to making our Kuros super quiet but it looks like it may only help in some of the cases.
                            How does the buzz volume compare to when you had the frame off?
                            Glad it helped out with the static sound at least.
                            • tn245
                              • Oct 2013
                              • 530
                              Also as previously mentioned, energy save mode 2 seems a necessity for some of them.
                              • Matcat
                                • Feb 2018
                                • 8
                                pretty sure the buzzing was way less with the frames off but i cant be sure
                                energy save mode 2 helps a bit
                                • Genjuro
                                  • May 2020
                                  • Denmark
                                  #56
                                  Hello folks, sorry to revive an old thread.
                                  My KRP 500A has started the same issue. While I was gaming it just began with the noises. I only have 7K hours on it. I have ordered the strips linked in this thread but it will take weeks before it arrives I gather as im in EU. Is it ok I have the tv on couple of hours a day untill its fixed or will it damage the tv etc? Thanks.
                                  • pixelcap
                                    Pioneer Kuro Pro 111FD 8 red blink error
                                    by pixelcap
                                    Pioneer Kuro Pro 111FD 8 blink red LED.
                                    I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                    So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                    based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                    10-06-2024, 11:26 PM
                                  • PowerAmpFreak
                                    Pioneer Kuro KRP-500 picture turns black
                                    by PowerAmpFreak
                                    This Pioneer Kuro KRP-500 plasma display has an intermittent issue in that it the picture turns black suddenly.
                                    Sound works all the time.
                                    Powerled is on all the time.
                                    This set has a separate control box which for a few years had a similair problem which was fixed by replacing a number of voltage regulators.
                                    Quite a common issue as fas as I know.
                                    Question is: are there more of the notorius voltage regulators also inside the display unit which should be replaced?
                                    Other advice?
                                    There are not a common cause which makes the issue. Can work for two days,...
                                    03-26-2022, 04:41 PM
                                  • ReeceyBurger123
                                    Pioneer Kuro PDP-428XD 8 Blue Blink Repair Video
                                    by ReeceyBurger123
                                    I'm back again bodging things
                                    Video covers the repair and diagnoses of my own Pioneer Kuro 428XD which went faulty with 8 blue blinks. Do not attempt anything seen in the video at home haha
                                    https://youtu.be/O0BS5kg3tNo
                                    02-21-2022, 12:12 PM
                                  • thie
                                    Pioneer Kuro KRL-37V issue
                                    by thie
                                    I have a Pioneer Kuro KRL-37V LCD TV with a problem. It's about 12 years old and was used as our main TV for about 9 years, it's now
                                    been moved to the guest appartment.
                                    I decommisioned it because after 4-6 years, don't quite remember when exactly, the follwing issue started popping up:
                                    When I power on the TV it initially works fine. As an example I plug in a chromecast and it will play
                                    several hours before the problem begins: a single green pixel will appear on the screen and stay green/become stuck.
                                    If I now switch the TV to a different input channel on which...
                                    01-13-2021, 11:44 AM
                                  • Bushcat
                                    Pioneer PL-X9 motor speed control wobble
                                    by Bushcat
                                    I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                    Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                    BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                    05-24-2023, 03:36 AM
