LG EAY60968801 Power Supply Unit(Plasma 50pk series)
  • tw2005
    • Oct 2011
    • 6458
    Re: LG EAY60968801 Power Supply Unit(Plasma 50pk series)
    Originally posted by flocko
    Keep up, so to recap PFC good at 390v but no VS have you changed the L6599A control chip ,what are you seeing on the outputs of Q801/802 primary side of VS transformer ?
    L6599A has been swapped out several times and also has been confirmed good placing it into the working board and no fault,
    So on the drain there's 198-200V there that's to cold gnd. Gate goes to 0, Source reads same as gate. There's a resistor between the G - S and when the relays relax it shows about 1.5v and tapers down
    • tw2005
      • Oct 2011
      • 6458
      Normal board around 45V where I have zip. On L6599A when i was pokinh arond I think RFMIN is close to 2v when running. Nothing on the bad.
      • flocko
        • Nov 2012
        • 1121
        you need to use hot ground (neg leg of main cap)the two primary side tapping on the transformer are in series what are you seeing across the them( you may need to check and compare with the good board ).
        • flocko
          • Nov 2012
          • 1121
          keep tripping over each other glad to see your on the ball,I think you have changed PC901 that will also stop the controller bringing up VS
          • tw2005
            • Oct 2011
            • 6458
            So for this continuing education. PFC can sub for 200v and 0.4 for th eother. Working 90-95V and PFC.
            As for the transformer I don't know what point but the same voltage as the transistor since it's switching the transformer.
            Yes PC901 has been swapped and I think that may be the one I spiked and took out the zener
            very reluctant to play with the new board now though seeing I'v replicated the fault onto a working (was) HD board
            • flocko
              • Nov 2012
              • 1121
              #26
              PFC can sub for 200v and 0.4 for th eother. Working 90-95V and PFC.Sorry you have lost me there? so where has the 390V PFC gone ? keep going you will get there but without me tonight , I am off to bed keep me updated good luck
              • tw2005
                • Oct 2011
                • 6458
                Sorry, I had to dive out suddenly. Right you said to change the gnd point which will change the values but in this situation somewhat academic. So PFC 390 is now measured ath e ths ame point as 200v and 0.4 in place of the 1,5v.
                No I won't find it this is my 4th straight wekend and every other spare moment I feel that I've put into it.
                • flocko
                  • Nov 2012
                  • 1121
                  #28
                  ok back for a short time, we are going round and round here, and i am getting giddy,so lets start again. Power board jump auto ground to ground standby should read 3.5v, make RL_ON high, relay should come in,stby should now go to 5v ,17v, AC DET 4-5v,PFC (read at F302/801) 390v.make M_ON high to give VS/VA.at what point does the board fail?my thoughts were at the M_ON stage but you seem to be having a problem with the PFC ?
                  • tw2005
                    • Oct 2011
                    • 6458
                    well it simply does not produce Va or VS. Va Vs and M5V all come on together with M_on going high.
                    M5V is good, zip on the other 2 and yes all other levels are correct. When the micro conroller fails to see Vs it retriggers the relays,
                    On a separate note I'm on a 42PJ650 with a EAY60912401. all these boards are essentially simlar designs, components etc of this period.
                    This one briefly flashed the panel. Fluked it on and left it running, turn off over night and same problem, 3 cycles and quits, difference being it is actually producing Vs and Va. Found the level had been knobbled at 190v.
                    anyway, after reflowing joints, rebuilding the resistor netwrok that feeds the micro processor, Mr Heat was applied.
                    Eventually she fired up once I hit the Zsus area.
                    Culprit was a dud 330uf 25V on ZSUS, changesd and now reliably turns on.
                    Tricky sets to work on.
                    Now thinking maybe, bad caps on the PSU is a possibility and this thread seems to indicate some similarities and fix doing the caps.
                    https://www.badcaps.net/forum/showth...0912401&page=3
                    • flocko
                      • Nov 2012
                      • 1121
                      #30
                      Replacing caps would be my first call on any failing power supply, second to dry joints? thought you would have that covered after four weeks, your slipping TW this is schoolboy stuff
                      • tw2005
                        • Oct 2011
                        • 6458
                        Very much doubt a schoolboy could fix this. Yes I may need re-training. generally don't need to do capwork, in fact very rare maybe because I don't work on this rubbish but hard times and very little Panasonic stock as every man who has internet access is fixing TVs.
                        back to the power board.
                        • flocko
                          • Nov 2012
                          • 1121
                          #32
                          Yes I have to say this forum and youtube has had a hand in putting a lot of old time Tv repairmen out of a job.If you keep putting wood on the fire sooner or later you are going to run out of wood.so I see it as rough justice, if you get my drift Flocko
                          • tvsteve2
                            • Aug 2014
                            • 25
                            • usa
                            #33
                            I have pulled my hair out on 3 of these then I got a tip to resolder the big transformers the top one was the problem and I couldn't see bad solder but a good hot resolder fixed all 3 I hope that's your problem
                            • tw2005
                              • Oct 2011
                              • 6458
                              Thank, I think I've tried tahst, they are really bad in the quality department. Out of location so it can lay. I've put the one and only good board back in a TV to sell, ready to quit on it. i would rather learn something from it though
                              • jalajjain
                                • Oct 2018
                                • 3
                                • INDIA
                                #35
                                Great discussion from all experts
                                I have LG 50Pw450. When i tuen on two clicks of relay heard back to back and then TV shuts off. I measured STNDBY on power board and it is 5.2V. No other voltage on any pin
                                Any suggestions
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                  by sam_sam_sam
                                  07-01-2024, 06:34 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
                                • CMCM
                                  Russound CA4 Power Supply Repair
                                  by CMCM
                                  Hello Everybody,
                                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                  The outputs marked 12v and 20v are all measuring only 1v.
                                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                  The capacitors physically look clean (no bludgesor leaks) and...
                                  07-03-2025, 01:12 PM
