i need dump arielli led2415fhd
  • freecom
    • Nov 2011
    • 18
    • greece
    arielli LED2415FHD
    stuck logo and reboot
    T.EME380.61
    panel AUOM24HTN (CX240LEDM) full hd
    spi 25q64
    i need dupm
    thank you !!!
  • cristy72
    Orion CLB22RT500d need good dump 25q64
    by cristy72
    Heloo. I need good dump for Orion CLB22RT500d . My dump is corrupt , continous restart .
    Mainboard is T.SIS231.31 , with 25q64 eeprom .
    Display : T215B1-P01-L05
    I atached here corrupted dump .
    Thanks in advance !...
    11-18-2024, 11:19 AM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
