Another Panasonic [TH-P50U20A] with 10 Blinks
  • Kosti
    • Sep 2015
    • 20
    Hey All
    I've got myself a Panasonic TH-P50U20A made in AUG 2010 and what started with a 10 Blinks with some basic checking a few threads and grabbing these PDF files below
    Panasonic_TC-P42S2_[SM]
    Panasonic_2010_PDP_S2_FHD_Troubleshooting
    I now have the 7 blinking symptoms, so out comes the TNPA5105 and sure enough shorts everywhere across various FETS transistors etc.
    I've not yet removed any of the components however after looking briefly at this thread Panasonic sc tnpa5081 rebuild there seems to be a varying amount of components
    I'm curious as on fleAbay there are several kits which contains most parts to be used on the TNPA5105 board and living in Sydney, AUS ebay or aliexpress is my best option to buy most parts, but there is not much difference from buying a kit or a used TNPA5105 board.
    So I am wondering if anyone has actually found the exact components that fail of are these always different from board to board? Also has anyone identified "better" higher spec'd components that survive these failures that occur on the TNPA5105 board.
    I've yet to rule out the buffer boards, which I will do over the weekend with a simple test as found in the utube
    https://www.youtube.com/watch?v=-JVLWpcIxJQ
    I will get some pictures up as soon as I find a suitable host since photobucket held us on ransom after offering free pix for years
    Keen to know if people have found better components to use as a replacement and if there is is a good place to source the parts
    PEACE
    Kosti
  • tw2005
    • Oct 2011
    • 6458
    Re: Another Panasonic [TH-P50U20A] with 10 Blinks
    If you can't get a 5105, throw a 5081 in there(50"). won't know the difference.
    there's generally very similar failures but occassionally you get one that's non compliant which kicks your ass. I had one recently. Two attempts failed, threw a 5081 in as I have them.
    You can sub other IGBTs. RJP56F4A, RJP43F4a for the Panasonic DG series. Could get away with the 56F4 for the 63F3.
    hard to know if you'll get fakes or not. Will probably involve some SMD work.
    • Kosti
      • Sep 2015
      • 20
      Thanks for that tw2005 - it's going to be one of those projects where I will work on it when times permits
      @tw2005
      How much can you source a TNPA5081 as it may save a whole lot of stuffing around in sourcing components, soldering etc and my eyes are not as good as they used to be
      Do you source parts from local electronics stores or just have a hole lot of bits and bobs around the place? Do you recommend those kits are worth it on fleabay?
      So is there a list of parts compiles or should I start removing until the S/C are gone
      BTW is the TNPA5081 and later revision or earlier one
      PEACE
      Kosti
      • jackfish
        • Dec 2016
        • 89
        • canada
        would the TNPA5081 work on the TC-P50U2 TNPA5105AB board as well?
        • tw2005
          • Oct 2011
          • 6458
          yep
          • Kosti
            • Sep 2015
            • 20
            Originally posted by Kosti
            @tw2005
            How much can you source a TNPA5081? as it may save a whole lot of stuffing around in sourcing components, soldering etc and my eyes are not as good as they used to be
            BTW is the TNPA5081 and later revision or earlier one?
            PEACE
            Kosti
            Any possible comment on the above ?
            • tw2005
              • Oct 2011
              • 6458
              Sorry mate. Kinda dropped off the RADAR with this forum, onto other things now.
              All mine are ones I've rebuilt. May have one but I have not built one now for 2 years
              Use to use UTSOURCE but had a falling out over fake bits blowing up and they hang me out to dry.
              It is highly unlikely any part marked as an original is real these days. More likely something that has been sanded down and restamped.
              Touch and go. Youmay have one that's failed differently.
              I had a 5105 and thought I had it covered , rebuilt twice blew up twice. probably had a 75% success on the few I've done
              You'd have to read through the forum threads including mine on 5081. I've done enough, the info is out there.
              5081 is same generation but out of the upmarket V series. Almost the same. the 5105 is a cut down 5081
              These TVs are not worth much now so what's the plan?
              Is the rest of it ok? Mainboard failure is also a common one in that U series
              • jackfish
                • Dec 2016
                • 89
                • canada
                So I can just swap the tnpa5105ab for a tnpa5081ak?..ak is one I found on eBay that's a 50 inch model..cheaper then getting a replacement 5105..half the price for replacement parts...
                • tw2005
                  • Oct 2011
                  • 6458
                  No, it needs to be AP,AF or Aw versions. AK is a 3D.
                  • jackfish
                    • Dec 2016
                    • 89
                    • canada
                    Ok..thanks for the info..be looking for one..had this tv sitting for a year..be checking the buffer boards as well to make sure they work..
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • CrewmanRedShirt
                      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                      by CrewmanRedShirt
                      Hello all,
                      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                      07-13-2024, 11:02 AM
