Panny TC-P50G25 bad SC board -- what else to check?
  • AnthonyC
    • Oct 2017
    • 10
    Thanks to the troubleshooting guide on this forum and many threads, I diagnosed a bad SC board on my Panasonic plasma TV. Dead short on the Vsus line to the SC board. Other boards connecting to power showed good resistance.
    No obvious damage to the board (scorch marks, cracked components, bulging caps). I checked the screws, since that was mentioned as a problem and they all seemed tight with no discoloration or other indications of arcing.
    Original symptom was the TV worked in the morning. In the afternoon, I heard the relays click, then click again, and no picture. It was blinking a four blink code.
    First -- anything else to check as to why the SC board failed short? I'd hate to repair/replace and have this happen again.
    Second -- self repair or send it out? I'm pretty good at soldering macro-size components but have no experience with surface mount. So I'm leaning towards paying for a repair.
    Is PTS Electronics still the go-to for this? I saw them recommended a lot in other threads.
    Thanks all!
    Anthony
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panny TC-P50G25 bad SC board -- what else to check?
    What board do you got?
    Usually the FETS get shorted. Check the components marked with "Q". ( For example Q661 ).
    Meter in diode/continuity mode and propes on outer legs. ( black on left leg , red on right and reverse ). Beep is bad.
    Same with the parts labeled with "D". They are diodes but you need to measure them differently. Black prope on middle leg and red on left/right leg.
    • tw2005
      • Oct 2011
      • 6458
      Thanks all!
      Anthony
      You could try the repair, most large kits probably cover the known bad bits, safest way is get it done if you're happy with the cost.
      Check the sd/su are still ok and not shorted. Then give the ol girl a pat and thank her for giving you 7 solid years .
      Why they fail, they do. Mine failed at 18 months and 2500 hrs. I now have 18000 hrs still waiting for another failure. One thing I noticed with mine (Rev AF) was some earth pads were missing topside compared to other boards I'd seen. WHO knows.
      generally there are no loose bolt issues it's the 2011 models that changed the bolt type.
      I just picked up one with only 4500hrs, blown sc. Looks like it's sat under the house for a few years. popped a spare in and she's all beautiful again.
      Considering the issues with LED backlights eg LG and TVs with lenses falling off and burning out in 2 years. I think the panasonic plasma has better durability and repairability. Bit hard on the Kilowatts that's all.
      • AnthonyC
        • Oct 2017
        • 10
        I have a 5081AF SC board.
        I'll take a look at the Q's and diodes.
        How do I check the sd/su for shorts? Specifically, which connectors and pins should I check?
        Thanks guys.
        • heavymachines
          • Mar 2011
          • 1028
          https://www.youtube.com/watch?v=-JVLWpcIxJQ watch this basically same procedure to testing any buffer boards on any plasma.
          • AnthonyC
            • Oct 2017
            • 10
            Question: which way is bad for the diodes to read? I was measuring middle out (black middle, then red on either of the legs). It seemed like they all beeped on both legs when I did that.
            The FETs were another matter:
            Q402 L/R short
            Q403 L/R short
            Q421 L/R short
            Q422 L/R short
            Q441 Okay
            Q442 Okay
            Q452 L/R short
            Q621 Okay
            Q622 L/R short
            Q660 Good
            Checking buffer boards now.
            Thanks.
            • AnthonyC
              • Oct 2017
              • 10
              Do I have to take the ribbons off to check the SD/SU boards? Seems like I could do more harm than good if I didn't have to.
              • heavymachines
                • Mar 2011
                • 1028
                best to test them by themselves so no false readings youtube how to do this safely and effectively its not hard to do.
                • AnthonyC
                  • Oct 2017
                  • 10
                  I also saw there is another row of pins under the ribbons. Just finished checking them and very carefully putting the ribbons back in.
                  No shorts to ground on any of the ribbons, so I'm hoping it's good there.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    If done right should be ...
                    • heavymachines
                      • Mar 2011
                      • 1028
                      Q402 L/R short
                      Q403 L/R short
                      Q421 L/R short
                      Q422 L/R short
                      Q441 Okay
                      Q442 Okay
                      Q452 L/R short
                      Q621 Okay
                      Q622 L/R short
                      Q660 Good
                      Thanks.
                      Depends on the of diode type. plenty of youtube vids , 3 legged diodes etc, zener, etc
                      • AnthonyC
                        • Oct 2017
                        • 10
                        I was more interested if these inparticular were supposed to be middle-out or outside-in for direction. It was late last night and I did not get a good look at the diode case markings. I'll give it a more thorough try tonight.
                        Where can I source the FETs? I tried the part numbers in Digikey and it came up blank. SJ has 5 packs of some parts, but were out of stock. Just wondering where else to look.
                        • tw2005
                          • Oct 2011
                          • 6458
                          You better read my TNPA5081 thread, There's some surface work and ICs needed too generally. Keep in mind if this goes wrong you won't be able to send that board to anyone.
                          • AnthonyC
                            • Oct 2017
                            • 10
                            I'm about 10% into that thread now. I'll keep at it, though. Thanks for the help.
                            Still leaning towards PTS. Just want one more day to take a look at things before committing.
                            • heavymachines
                              • Mar 2011
                              • 1028
                              List the numbers and someone will list a compatible one that will work.
                              • AnthonyC
                                • Oct 2017
                                • 10
                                I caved and sent it to PTS. They got it Monday and I got it back today. Plugged her in and it fired up nice. I looked at the menu and it appears all lines look fine. I'll plug it into the cable box and see full video to verify.
                                Thanks for the help. Even though I didn't do the soldering, it was nice to know I had the bad board isolated and what was wrong with it.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  not a bad idea, stress free. look at that, identified the bad bit sent it in, rebuilt, installed watching telly
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • Hakuu
                                    by Hakuu
                                    Hi There,
                                    More Details
                                    TV Model - LG OLED77G1PUA
                                    07-12-2023, 02:37 PM
                                  • MacGyver's paperclip
                                    what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
                                    by MacGyver's paperclip
                                    TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
                                    07-01-2023, 12:12 PM
                                  • canadaboy25
                                    Panasonic TC-P54VT25 No image. A or D board?
                                    by canadaboy25
                                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                    01-17-2021, 01:06 AM
