Re: panasonic tc-p50s60 bricked after firmware update?
They should take care of you, as i have yet to get anything junk yet from them but it is possible.
yeah it is found this one and will work have yet to get anything bunk from them.
http://www.tvpartstoday.com/TXN-A1US...sh-a1usuus.htm
Little pricey but will stop the woes, get a refund on the bunk one.
You have to call them to set up a return, I might do that tomorrow or at least see if they will exchange the A-Board I purchased for the one they have in stock now.Last edited by mushchampion; 10-24-2017, 09:59 PM.Leave a comment:
Little pricey but will stop the woes, get a refund on the bunk one.Leave a comment:
http://www.shopjimmy.com/panasonic-t...-tc-p50s60.htm
Is that same as yours part number and all? i'll see if i can find you an A boardLeave a comment:
if they're indeed same exact board yes it is possible, but it would make more sense to copy the bin from it and transfer it to the other rather than butcher possibly good board, but then again we don't know if it's rom er bin is corrupted or not which may very well be the reason replacement not working.Leave a comment:
Think you're gonna need one of these and flash original back.
https://www.ebay.com/itm/USB-BIOS-EE...ss!49457!US!-1
Looking at these boards, none of these chips look removable, at least not for a novice like me - but if an IC swap on the main boards seems like a plausible solution, I could bring the boards to a local professional to do it for me.
I appreciate everyone's help and suggestions in this thread, getting into the EEPROMs and Integrated Circuits and going down to that level has me a little overwhelmed, and is a rabbit hole of research to understand all of it.Leave a comment:
https://www.ebay.com/itm/USB-BIOS-EE...ss!49457!US!-1Leave a comment:
Why did you originally update the f/w in the first place?
--What faults indicated to you to go to that extreme?
Regardless of what makers say, when updating f/w there's always a possibility of bricking it--no matter what the thing is, let alone TV sets with their multitude of different versions--Of the same set!
Route of last resort in my book, leave f/w alone unless you know for sure its the cause of the problem, and if there IS NO Problem, defo dont do it--don't even think about it!
That being said, for most of the time I've owned this TV, I haven't even had the internet options turned on. I had a roku3/cable box/pc all hooked up to this TV through an Onkyo receiver so I never really ever used the few built in apps/features that this early smartTV has... I was wanting to move the roku to a different room with an older TV.Leave a comment:
Can you take a clear picture of the SC board? Especially the bottom left area , is there a SC50 jumper? ( between 2 white connectors )
If so , remove the 2 buffer boards or make sure they DONT touch the sc board. Use a harddisk jumper or something else and short the 2 pins. Turn on the tv and see if it stays on.
What it does is turning on the tv without sending a image to the panel. If it stays on you got bad buffer boards.
If the 6 blink error stays on BOTH sc boards your problem seems to be the mainboard. I will look in the service manual when i get home.
Let me know what the outcome is!
The result was the same 6 blinks. I haven't tried my original SC board yet, that's next. (edit: I put the original SC board back in, with the jumper, and got the same 6 blinks)
If the TV Stays on with no signal being sent from the buffer boards.... how will I know? Will I be able to pull up the onscreen menus and such?Leave a comment:
Route of last resort in my book, leave f/w alone unless you know for sure its the cause of the problem, and if there IS NO Problem, defo dont do it--don't even think about it!Leave a comment:
Ps , with the old mainboard installed im sure you tried the power button on the remote itself? It wont come out of standby with the power button on the tv or other buttons.
Also double check the SC20 cable , release both hatches and pull them open untill they cant go any further. Take the SC20 connector and slide it in. Maybe clean the sc20 cable wih some alcohol and look inside the connector.
It happened to me once that i had a faulty sc20 cable due to heat/dust etcLast edited by Moreno83; 10-18-2017, 11:12 AM.Leave a comment:
You should not have bought the sc board to be honest. I get it , you want the tv to be working again but dont go buy random boards. Waste of money.
Just looking at the picture you provided i think you received a bad A board ( mainboard ). But that is just a guess.
Let me know what the outcome is!Leave a comment:
Should be good then. Formally tristate module. i have yet to receive anything bad from them, anything but it is possible to get a bad part but i can tell you they have called me before they shipped an order of multiple parts to let me know one was damaged and failed test so the order had to be modified.Leave a comment:
tvpartstoday.com
Same place I got the A-boardLeave a comment:
Where did you get the board?Leave a comment:
Update : got the new SC Board, installed it. Still getting 6 blinks. I tripled checked all the connections and screws before I even plugged the thing back in.
I'm all out of ideas on what the issue could be. Really don't want to go in on more parts (the SU and SD Boards).
Also about all out of patience, guess I'm going to start looking into new TVs.Leave a comment:
i guess you need to re-flash the ROM ic.find a programmer and re-programme tha ROM ic.
RT809F or RT809H (find the bin file)Leave a comment:
try the old a board back in .Leave a comment:
I went ahead and ordered the SC Board, I figure what's another $30(45 w/ shipping) if it saves me buying a new tv. I really love my Panasonic Plasma, and I got it for next to nothing from Sears shortly after Panasonic announced they wouldn't be making plasmas anymore.
I'll update again next week when I get the new SC Board.Leave a comment:
by mallard729Hey all
So my rock solid p65 (lol) got stuck with a auto firmware update stuck at 20% for a few hours, finally had to hold down power button, tv is now in the logo reboot loop, cycles about every 25 seconds. the buttons on the back of the tv do not seem to function, i tried loading firmware with no luck... nothing is recognized.
in my course of research i think that the eeprom u202 got corrupt during the failed update, i have reached out to vizio, but not hopeful as tv is long out of warranty. Wonder if vizio would at least send me the .bin file for the u202 chip
I have been... -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...02-10-2024, 02:07 PM -
by codernov
https://i.ibb.co/Z1hKTkwW/0001.jpg
https://i.ibb.co/BK7YmhHx/2025-06-06-16-14-IMG-5818.jpg
This thing is pretty expensive. More than an average notebook.
Anyway. I got this job over facebook market place. Customer said he bought it used and it was working fine, then he decided to upgrade firmware and somewhere along the way the battery died or whatever we don't know, it got bricked. That's his story and he's sticking with it.
If we connect power supply to it, we are getting 21 milliamps and nothing is happening. Pressing buttons does nothing....-
by rumpumpel1Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?10-24-2024, 08:59 AM
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... - Loading...
