Samsung UA60EH600 weird startup
  • The_Todd
    • Jul 2017
    • 66
    Hello guys,
    So this issue has really got my head scratching...
    So this came in no picture and blinking red led. (Wow much original)
    Anyway all caps are fine, 5v standby is fine, and from what I can mesure the power transistors are also working fine, but nothing..... Anyway...
    I was doing some voltage checks on the power cable that goes to the main board (disconected from mainboard) and upon testing the power on/on cable is just turns on as far as back light and voltages are concerned..... And stays on???
    Plug it back in to mainbaord and it working semi ok, apart from staggered startup.
    So my logic is this.
    A normal board is normally off unless otherwise said
    This appears to be on unless otherwise said....wtf
    So Q1. What the hell did i do?
    Q2. How does the power pins work? Is it to ground or to 5v? And with a resistor
    Q3. Whats the difference between "power on/off" and " BLU_on/off"
    Q4 on a slighly diffrent topic there is a smd resistor looking thing with a marking "30C" and is labled RQ864 what is it?
    Cheers, thanks.
  • The_Todd
    • Jul 2017
    • 66
    Re: Samsung UA60EH600 weird startup
    And here is the pin layout for the cable.
    Oh also my guess for this problem is a dodgy transistor, before it was stuck close and now it is stuck open?
    I also forgot to mention that i was "TOLD" this tv would turn off and on randomly, (caps i thought) but no, not that easy
    • The_Todd
      • Jul 2017
      • 66
      Hey sorry to ask 9001 questions,
      But regaurding the back light curcuit, as the is essentially 4 outputs ( what goes into 6 wires) all controlled by 4 mosfets. Is it controling 2 lots of leds curcuits with a positive and a negative gate? Or am i way off and need to check myself?
      Cheers
        So let me get this straight, if you disconnect the cable between the power supply/LED driver board BN44-00500A and the main board then apply AC you will the get the backlights to come on right away and backlights stay on as long as the TV is plugged into the AC outlet?
        If that is the case then your power supply board is OK, this power supply probably has pull-up resistors for doing the self test.
        We also need good clear pictures of the whole back side of the TV so we can see how all the boards are connected together.
        "power on/off" = PS-ON/OFF
        " BLU_on/off" = BL-ON/OFF = Backlights ON/OFF
        You have two set of LED strings so it has two MOSFETs for two Boost converter circuits, two PWM Controlled MOSFET for controlling the current through each string of the LED.
        • The_Todd
          • Jul 2017
          • 66
          Yes, with power connected, but mainboard left unconected it "turns on"
          Also in this setup the only thing connected is the backlight. This is very weird everyother board i have worked on is always off unless activated.
          What is the purpose of this pullup resistor to turn it on? Does this mean the main board keeps it "off" in other words the powerboard is always on, unless it has been told to stay off?
          Picture included
            Picture included
            The pull-up resistors are for simulating the ON command signal from the main board so the tech can easily isolate the problem in the field instead of using resistor between STBY power supply and the PS-ON pin and the BL-ON pin while trying to service the TV. They did not do that in the earlier version of the TVs so you have to do the force on yourself with the resistors.
            Sounds like you have problem in the main board. You can record the DC V on the PWR ON/OFF pin and the BLU-ON/OFF pins as they are right now without the main board connected and the compare them to the readings when all boards are connected and the TV is not working so you can see what are missing.
            • The_Todd
              • Jul 2017
              • 66
              Oh wow, I didnt know that, thanks for the advice,
              Well as I said originally this was not working, even when disconected, then after slightly grounding pwr on, its now working normmally, doesnt make sense to me...
              So is are the to power pins meant to be shorted to ground to turn on or conect to 5v to turn on?
              Cheers.
              • The_Todd
                • Jul 2017
                • 66
                Ok so these are the test results
                No main board
                Pwr - around 3v but keeps jumping around anthing down to 1.5v also makes the psu make a soft buzz noise everytime conected to the multimeter...weird
                BLU - 3v exactly
                With main board conected (and tv on)
                Pwr - same as above
                Blu - 5.9v
                Main board (standby mode)
                Pwr 0.4 jumping occasionally to 0
                Blu - 0v
                Why is pwr acting so strange....
                Cheers
                • The_Todd
                  • Jul 2017
                  • 66
                  Well, I did resolder a couple of startup capacitors on the primamry side of the main transformer curcuit, and its been running 2 hours non stop. Still i have my doubts..... Guess it was a dry join, Time will tell.
                  The overal power pins cucuit still leaves me a bit confused. Ive also realised this actually has dynamic backlighting, is this what the BLU curcuit is for? Variance to pin voltage variances the out put voltage to the leds?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    when re soldering the capacitors on the power supply the heat may of lowered the esr on them hence the set is now starting up ok if it fails too start again just replace the capacitors with Panasonic brand
                      I would also re-solder all the transformer legs and all the legs of the components that are mounted to the heatsink, especially the one with through rivets.
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
