Samsung UN46D6003SF Shows "Samsung Smart TV" boot screen, blinks red light 5 times
  • Beef_Ramen
    • May 2016
    • 22
    • US
    Samsung tv shows the boot screen as soon as plugged into an outlet, blinks a red light 5 times, then goes all black, touch buttons seem responsive by blinking a red light when pressed, but nothing happens. Picked this TV up on the side of the road after huricane Irma, very nice condition. Looking to get up and running if not too expensive. Can provide pictures/videos of needed.
    Thank you.
  • heavymachines
    • Mar 2011
    • 1028
    Re: Samsung UN46D6003SF Shows "Samsung Smart TV" boot screen, blinks red light 5 time
    Most likely water damage, well read the stickies and post pics of back of all the boards and give what voyage readings you do have.
    • torchzack
      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
      by torchzack
      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
      08-28-2023, 07:42 AM
      09-07-2024, 05:50 AM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
      09-06-2024, 11:40 PM
