Sharp Aquos LC-60LE832U ON-OFF cycling
  • emilfedorenko
    • Sep 2017
    Hello
    I have subj
    1. if i power on TV for the first time - it works about 3-40 second and then power off .... in this time i can change channels, input source use menu - but too short time to made full reset...It power off after 30-40 seconds
    2. After that it begun to power ON (only ^ logo) for 5 sec and OFF for 30 seconds and cycling forever
    3. If i unplug it and wait about 1 hour - it begin working like in 1. and then goes like 2....
    Can anybody help me....thank you!!
  • scubacamper
    Sharp Aquos LC-70C6400U Half Screen Dark
    by scubacamper
    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
    05-03-2025, 12:19 PM
  • sefoster
    Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
    by sefoster
    I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
    11-20-2022, 09:29 AM
  • jonah1024
    Sharp Aquos LC-40UG7252E LCD TV burn in?
    by jonah1024
    Hello!
    I'm a few days old into this TV screens repair universe so please bear with me.
    Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
    - I did the classic unplug and hold power button to discharge the caps but it didn't help.
    - I did a factory reset as well...
    07-16-2024, 04:23 AM
  • high-tech
    Samsung UN55F7050AFXZA ver. TD01 power cycling
    by high-tech
    Hello everybody, I could use some help on this one... It's got me guessing...
    I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
    (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
    (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
    (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
    (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
    9. ground (PWM2) 10. 0.9 volts cycling...
    09-15-2020, 03:39 PM
  • klassic
    Sharp Aquos LC-60LE635E three blinks
    by klassic
    Hi community,
    I will describe my problem with a TV in those short following terms to be the most precise :
    What i have :
    power board DPS-162KP-1
    main logic board QPWBXF733WJN2
    symptoms :
    white led light logo at startup,
    after 2 minutes, blinking 3 times a row, repeating
    no backlight (and apparently no picture, checked panel with flashlight)
    no startup sound
    powerboard investigations :
    1-2 PNL : 0v
    3-4 GND
    5-6-7-8 UR : 13.15v
    9-10-11-12...
    10-24-2023, 01:39 PM
