Sony stand screws
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Sony stand screws
    Hello,having checked ebay £8 for four screws ! Where can I get replacements a lot cheaper m5x16m please quote me if I'm wrong.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Sony stand screws
    Ouch ! Just regular silver pan head screws ?
    I have a fastener place near me, I paid a quid for 20 VESA mount screws last time I went in.
    If I get a chance tomorrow I'll pop in for you.
    • zomi
      • Nov 2011
      • 512
      tool station, screwfix
      check them out
      also can search ebay just fpr the size
      not for 'sony'
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        they looked black in the picture,
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          just noticed it missing the brackets just great
          • dominik0801
            SONY KDL-43W755C | 5 blinks stand-by LED
            by dominik0801
            Hello guys.
            Today I got this TV for free, the friend included a "new" (used) TCON with it, since he told me, that doesn't work either.
            With the stock TCON, this TV turns on, stays on, but the screen only has 5 RED vertical lines on it, and that's it.
            Backlight stays on and is fine.
            With the "new" TCON, the TV turns on, shows SONY logo, some spinning circles, then the TV goes blank, and the stand-by LED is blinking 5 times, won't react to anything.
            I have read some forums, where it's been told that the part number is not always enough...
            12-18-2023, 11:40 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • DXseekerMO
            Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
            by DXseekerMO
            Hello everyone!
            Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
            Symptoms:
            1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
            2) TV does not appear to turn on
            3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
            4) "Power on" terminal on Power Supply has 3.26v
            5) "A13V" terminals have 12.9v
            6) Stand-by test jumper on Power Supply has 12.9V
            7) Optical audio jack on Main Board illuminates
            8) With stand-by...
            06-09-2021, 12:19 AM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
