Vizio D65u-D2 backlight issues
  • JunkmanJimbo
    • Mar 2017
    • 194
    I have removed the led panel, plugged in the tv and powered up the backlights to determine which backlight strips are defective. I replaced the strips that were suspect and now all strips light up for a few seconds and then the top and bottom strips on both sides (4 strips) go out. After a few minutes the tv then shuts down. I have tested each strip individually with a led tester and each strip shows all led's working. I replaced the power supply board and the led driver board with used boards that I believe are good boards. Any ideas or suggestions will be very much appreciated. Thanks in advance.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Vizio D65u-D2 backlight issues
    I have had backlight strips that tested 'good' but when connected to PSU they go out. My recommendations to you are:
    (1) Check the connections on the strips and ensure they are secure by re-soldering them.
    (2) Replace the original LED strips with new strips, so that all the strips would have been replaced.
    • JunkmanJimbo
      • Mar 2017
      • 194
      I forgot to mention......I swapped the connector from the working led strip with the non working led strip and the non working led strip then lights up and the working led strip does not work. It's like the wire harness is defective but I tried another wire harness and I get the same results. Any ideas? Thanks.
      • JunkmanJimbo
        • Mar 2017
        • 194
        Just wanted to share this with hopes of helping someone else. The backlight issues I was having actually turned out to be the mainboard. I hope this might save someone some time in their diagnoses.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Thanks for the follow up.
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • smort
            Backlight Polkadarks
            by smort
            Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
            I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
            03-11-2025, 12:33 AM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
