Pioneer plasma KRP-500P blinks
  • PowerAmpFreak
    • 977
    • Sweden
    This Pioneer plasma with external mediabox/reciever doesn't want to turn on always. The leds on the mediabox blinks red/blue.
    I wonder if there are the notorius 1.8V regulators inside the mediabox as in PDP-5090's that cause it sometimes to not power up?
    Any advice is appreciated!
    Re: Pioneer plasma KRP-500P blinks
    Yes, there are.
    • pixelcap
      Pioneer Plasma 111FD To Solder or Not to Solder.
      by pixelcap
      Hello out there in Badcap land.
      I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
      are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
      Thank you
      Pixelcap...
      03-08-2025, 07:10 PM
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • Phil Stasik
      Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
      by Phil Stasik
      Pioneer Pro-FHD1 Elite. Failure to power on.
      I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
      We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
      01-19-2023, 01:22 AM
    • M80
      Samsung PN51E550D1FXZA plasma no power up 2 blinks
      by M80
      Samsung model # PN51E550D1FXZA plasma TV after a lightning hit (LAN cable was connected to TV). Standby LED on ok, but when pressing the power button, getting 2 blinks on the red LED, the screen flashes white for a second, and then cycles through this loop routine.
      ALL voltages Vs, Ve, Vsc, Va check ok at SMPS output pins and at Main Board connector and X/Y drive board test points.
      Noticed the Logic Board LED lights up green for a couple of seconds, hums lightly, then goes off during this cycling.
      I've reseated ALL connectors and none of the boards have any burned traces or...
      08-11-2022, 04:34 PM
