Sanyo DP52449 audio no video
  • joeshannallie
    • Dec 2013
    • 103
    • usa
    I just have a question and need some advice. I have a Sanyo DP52449 Tv and can get audio but no picture. I have checked the voltages from the power supply board(please see pic) and the 5v is there but the 12 or 15v is not there. The screen is only like a bluish color nothing else. I connected tv cable and was able to get audio. My main question is could power board be some bad and not all the way dead? You know like I could still get audio but no video. I have also replaced the Tconn board. Please reply soon with any advice you may can give.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sanyo DP52449 audio no video
    What is your ps-on voltage in standby
    • joeshannallie
      • Dec 2013
      • 103
      • usa
      Stand by voltage is 4.
        Are you sure that your meter is good? 4VDC for STB5V is low.
        How about the DCV of that PS_ON/OFF pin when the TV is OFF and when the power switch is activated?
        We also need the pictures of the whole board and the whole backside of the TV showing all the boards so we can see how all the boards are connected together.
        • joeshannallie
          • Dec 2013
          • 103
          • usa
          Thanks Bud for the reply. I assume the meter is good. No reason to think it isnt. I will get more pics a little later today.I was testing voltage by having the set of wires unconnected as you see in the pic and just touching the pins after I pressed the power button. Was that the wrong way? Do I need to check the voltage with everything connected?
            You need to test the Voltages with every thing connected first because they communicate with each other, read the Basic LCD TV and Monitor troubleshooting guides to get basic idea as how each board interact with each other.
            • joeshannallie
              • Dec 2013
              • 103
              • usa
              Ok I checked all the voltages with everything connected and tv on. The results are not good I dont think
              Small White Connector on Power board=
              LDP-1= 010v
              LDP-1= 010v
              gGND
              GND
              GND
              LCF= 0v
              12v= 011v
              Small connecter next to main board connector on power board
              NC
              BL_ADJ=002
              BL_ON=002
              GND
              STB5V=004
              Main board connector to power supply
              Line/Off=0
              15v=0
              15v=0
              GND
              GND
              12v=0
              12v=0
              12v=0
              12v=0
              GND
              GND
              D5V=0
              PS on/off=0
              That is the best I could do. May pick up a new battery for the tester and double check again shortly.
              Here is some pics
              Also the audio is choppy like with out the cable connected.
                What Voltage scale are you using? It looks like you are using too high of the Voltage scale that is why it is showing 004V, you should use 20V (19.99V resolution) scale.
                But the bottom line is that the main board is not sending the PS-ON ti turn on the rest of the power supplies.
                • joeshannallie
                  • Dec 2013
                  • 103
                  • usa
                  So in your opinion the main board more than likley is bad, Right? Can not find one anywhere. Found a few and they all seem to be missing a connector. Why do you think it has audio but no picture?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Does ps_on change voltage when you push power button?
                      Line/Off=0
                      15v=0
                      15v=0
                      GND
                      GND
                      12v=0
                      12v=0
                      12v=0
                      12v=0
                      GND
                      GND
                      D5V=0
                      PS on/off=0
                      That has to be measurement error, no way you can have the backlights on with all the Voltages on the main board connector to be ALL 0V.
                      https://www.badcaps.net/forum/attach...5&d=1505421797
                      • joeshannallie
                        • Dec 2013
                        • 103
                        • usa
                        Will find a different tester today.
                        • joeshannallie
                          • Dec 2013
                          • 103
                          • usa
                          Got a different tester today at wally world and the main board connector voltage did not change. Others did.The small connector next to the main board connector on the power board with the new tester now reads
                          NC
                          BL_ADJ=2.93
                          BL_ON=3.29
                          GND
                          STB5V=5.03
                          Main board connector voltage stayed the same on or off
                          Little connector at the top of the power board changed with new tester
                          LDP-1= off 0.28 on 11.31
                          LDP-1 = 0.29 off 11.31 on
                          GND
                          GND
                          GND
                          LCF=0v
                          12v= 0.33 off 12.19 on
                          Tried every way possible to get readings from main board connector and had no luck. So I assume it is the main board but how can I be certain that it is not the power board since I get good audio with cable connected?
                            Where is the PS_ON/OFF?
                            So now your STB5V=5.03 instead of 4V on the meter with high scale setting.
                            BL_ADJ=2.93: The main board is sending the Backlight level command as it should
                            BL_ON=3.29: The main board is sending the Backlights on command as it should, that is why your backlights are on.
                            12v= 0.33 off 12.19 on: The switched 12V is working and it is being turned on the main board which means the PS-ON command from the main board is preset but you did not list he Voltage from that pin.
                            Where is the 15V pins reading per your post 7?
                            Where is D5V per post 7?
                            So as far as we know now is that the backlights (lights source) are working but you are no seeing the images on the screen.
                            No image can be due to main board or T-CON board.
                            • joeshannallie
                              • Dec 2013
                              • 103
                              • usa
                              There is no voltage at all coming from the power board to main board connector. I will try and probe them a little harder today. I was being gentle with the connector. I thought I probed it fine but I try again today.
                              • joeshannallie
                                • Dec 2013
                                • 103
                                • usa
                                New readings after probing a little harder.
                                Line on/off = 4.97
                                15v = 15.74
                                15v = 15.74
                                GND = 0.00
                                GND = 0.00
                                12v = 12.18 on 0.49 off
                                12v = 12.18 on 0.43 off
                                12v = 12.18 on 0.40 off
                                GND = 0.00
                                GND = 0.00
                                D5V = 5.01 on 5.01 off
                                GND = 0.00
                                PS on/off = 4.99 on 0.00 off
                                So what now? I did check the voltage of a big canister that had 400v on it and with power on it only went to 44v. That was on the power board. Can not find a exact main board no where.
                                  That looks good, you do have backlights so that is also good. The next thing to check is to find out if the T-con board is getting the 12VDC on both end of the fuse with reference to GND or not.
                                  • joeshannallie
                                    • Dec 2013
                                    • 103
                                    • usa
                                    Could you possibly tell me how to do that?
                                      Your TV is going to be easy, see that metal box in the middle between the power supply board? The is the FRC (Frame Rate Conversion board) which get the signals from the main board then it has two output connectors that go down the plastic chassis of the TV to the T-con board on the LCD panel, so the problem can be the FRC board or T-CON board. It can be that the FRC board is not getting the power.
                                      http://www.shopjimmy.com/catalogsear...=Sanyo+DP52449
                                      The connectors on the FRC board has no labels for the pins. We will need to find the service manual for this TV to make it easier to test the Voltages.
                                      • joeshannallie
                                        • Dec 2013
                                        • 103
                                        • usa
                                        I have the service manual. Is that small connector just a extra one on that board? Makes you think there should be wires going to it.
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
                                          HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                                          This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                                          09-12-2024, 03:36 PM
                                        • SolarFlare
                                          Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                          by SolarFlare
                                          My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                          The TCON board has the following Chips -
                                          Samsung VTU63A0
                                          RT6939 - 2nos.
                                          and all these chips are getting real hot within a minute, I dont know if this is normal....
                                          06-26-2022, 08:58 AM
