Samsung LA40C530F1R Backlight goes off/ 5v detect drops
  • EDE
    • Feb 2019
    • 12
    • South Africa
    Re: Samsung LA40C530F1R Backlight goes off/ 5v detect drops
    I will check today. And get back to you soonest.
    What was strange is the TV came on for a minute then shut down again after trying to clean main board.
    • EDE
      • Feb 2019
      • 12
      • South Africa
      I will check today and get back to you.
      • EDE
        • Feb 2019
        • 12
        • South Africa
        Hi Budm,
        Ok, it makes sense. I will check today and get back to you. I actually measured the wrong board(PS).
        Apologies.
        • EDE
          • Feb 2019
          • 12
          • South Africa
          Hi Budm.
          I measured Pin 2 DET on main board 21.9kohm (isolted from PS Board)
          and when connected Main to PS = 7.5Kohm@ pin2 DET
            • 12323
            • U.S.
            Looks like the mainboard isn't sending the ps-on signal properly.
            • EDE
              • Feb 2019
              • 12
              • South Africa
              #26
              Hi thanks for your input.....
              I tried cleaning Main board with isopropyl alcohol and tv is on now! Weird! is this then due to flux on board?
                So now 5V_DET is high now?
                  • 12323
                  • U.S.
                  #28
                  "18. PS_ON 0.7V" then you must have read it wrong, don't see how the powerboard comes on if this never goes higher than .7v.
                    1. B13V 12.2V
                    2. 5V_DET 3.4V
                    3. B13V 12.2V
                    4. BLU_ON 5.2V
                    5. B13V 12.2V
                    6. E-PWM 3.8V
                    7. GND 0.0V
                    8. H_SYNC 1.8V
                    9. GND 0.0V
                    10. GND 0.0V
                    11. B5V 5.2V
                    12. GND 0.0V
                    13. B5V 5.2V
                    14. B5V 5.2V
                    15. B13V 12.2V
                    16. A5V 5.2V
                    17. B13V 12.2V
                    18. PS_ON 0.7V
                    That my be typo but since all the switched power supply Voltages are present and probably the PFC Boosted Voltage too are present which means the PS-ON control signal is good enough to turn on all those switched Voltages.
                      • 12323
                      • U.S.
                      #30
                      Indeed.
                      • Bhekifa
                        • May 2020
                        • South Africa
                        #31
                        Originally posted by Grunder
                        Hi Vince, thanks, quite right, one of the lamps turned out to be faulty. The other lamps also look blackened at the tips. Can the lamps be bought loose? I took one out of a scrapped panel and managed to get the lamps running. (photos)
                        Thanks again input from Budm & tvtimmy as well
                        Hi
                        Was you tv fixed after that because mine is giving me the same problem
                          • 12323
                          • U.S.
                          #32
                          These models are pretty easy to test compared to some others, not exact same models there but gives you the gist of testing: https://www.youtube.com/watch?v=oE6K4xBVweA https://www.youtube.com/watch?v=Dh01ZepjDp0 https://www.youtube.com/watch?v=lvBo3vetuGs
                            • 12323
                            • U.S.
                            #33
                            I believe there's a nifty little lamp bypass in one of those, for those who don't feel like tearing down an old tv and trying to find tubes that match. It works if you have a bad tube OR a bad transformer which both can be a pain to find, it gets you going but with one lamp bypassed so there's a slightly dimmer section running across the screen but it's not really very noticeable, second video I believe.
