hisense H43m 3000 looses sound and picture
  • adamp91gvm
    • Jan 2014
    • 706
    • uk
    every now and the it goes off and needs turning off at the wall then turns back on when switched on
  • Hamie
    • Apr 2014
    • 1383
    Re: hisense H43m 3000 looses sound and picture
    I'd say it's either the; power supply, mainboard, TCON, leds, remote sensor or buttons causing your fault.
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • jake12021
      Hisense 65p7 sound but no picture
      by jake12021
      I have got a Hisense 65p7 tv. The red standby light is solid when plugged in. When turned on with remote the red standby light flashes 17 times and then stays off. The screen lights up the smallest amount and need to turn off with remote again to get back to a solid standby light. Ive already gone through replacing power board and main board and neither fixed the issue. The back lights under the back panel are lit up when tv is on and sound still works. Wondering if I should try to replace the t-con board? Or is there any tests for the leds? (I have a voltmeter)...
      02-19-2023, 08:43 PM
