Phillips 50PFP5332D/37 Plasma HDTV - No Picture, Has Sound
  • grimacelord
    • Jan 2017
    • 377
    Hi guys. Back again, this time with a Phillips plasma HDTV. Symptoms are no picture, but has sound. TV does power on with blue power light and I can hear the relays click and a slight buzzing sound from the Y-Buffer/Main area. LED on Y-Main stays solid while LED marked LED2002 on Main Logic Control board blinks endlessly in no specific pattern.
    I have already searched the forum for other cases and have found multiple cases of the same scenario, but sadly, most of those threads never were updated or the repair was abandoned before a solid repair was found.
    I found 2 bad caps on the Y-Main and one on the X boards, totalling 3. After replacement, the TV showed no improvement. Same symptoms.
    I have also tried unplugging Y/X individually to see if the TV responds any differently and it doesn't. Same symptoms.
    I took readings from all of the power connectors on the main power board and all of the voltages are within range according to what is printed on the board, so that seems to be ok. I also tested all of the fuses, and they checked good.
    Any suggestions on where I should go from here? Attached are some pics and I can get more if need be. Thanks a lot guys,
  • grimacelord
    • Jan 2017
    • 377
    Re: Phillips 50PFP5332D/37 Plasma HDTV - No Picture, Has Sound
    Anyone?
      See if there is a green LED lit on your Y-main, if so this indicates there is a Y-main protection fault.
      • grimacelord
        • Jan 2017
        • 377
        There is. It is a solid green LED. So where do I go from here to determine if it is Y-Buffer or Y-Main or something else entirely?
        • grimacelord
          • Jan 2017
          • 377
          So, I just tested the Y-Buffer board's ICs by following this video: https://www.youtube.com/watch?v=V6hxf9sARMY
          None of the ICs had short to ground.
          Still stumped on what to check next though
            Get this file:
            http://www.toms-service-manuals.com/...&Search=Submit
            The plasma panel in your TV is made by Samsung, but this service guide was written by Philips, because Samsung refuse to document the repair procedure.
            See page 54 as it refers to the protection LED.
            Page 65 has some relevant voltage checks.
            • grimacelord
              • Jan 2017
              • 377
              Get this file:
              Alright, so after reading through this service manual, I have replaced the Y-Main board. The new board no longer shows the Y-Main protection fault light. I was still not receiving a display, so I took a second look at the X-Main board and found a fuse that was bad. I replaced it with a working fuse. (see attached image for location)
              Now, the TV is actually trying to produce an image! I'm getting the snowy-static, but the image seems to be coming in and out. So it will go black and then back to snow/static, and then back in about 2 second intervals.
              What should I do now? I'm close!
                Can you post a picture of this snowy static? It sounds like an X-main problem if you are getting that.
                • grimacelord
                  • Jan 2017
                  • 377
                  I'll try to. I'll probably have to take a video and upload it to YouTube or something because it flashes in and out. So when I first press the power button, I hear the relays click and then the image of the snowy-static appears for a second or two and then it's all black again, but then it comes right back a second or two later and it does this on repeat over and over.
                  This is the first time I actually got an image out of this TV and it happened only after replacing that fuse I mentioned in my previous post. I also had replaced a capacitor on this board that was visually bad, but that seems to be the only one as all of the other ones look normal (I realize they can still be bad and look normal though).
                  While I work on getting a video/picture for you, do you have any suggestions on what I could troubleshoot next? I have been following the service manual you gave me and tested the components that they suggested I test in the manual, but all of those seem to be testing fine. I'll repeat it once I get to work just to verify though.
                  Thanks for all your help!
                    Verify all the voltages on page 65 of that document. In particular Ve is very important as low Ve can cause a poor image.
                    • grimacelord
                      • Jan 2017
                      • 377
                      Alright, here are the voltages that I am reading.
                      VS: 190-215DCV (This one fluctuates and corresponds to how the TV image comes in and out. So when the image is out, it's around ~190DCV. When the snowy/static image comes in, it's 215DCV. Endless loop of this)
                      VA: 56-65DCV (Same behavior as above ^ )
                      VG: 15DCV
                      D5V: 5.22DCV
                      5VSV: 5.24DCV
                      VSND_POS: 17.27
                      VSND_NEG: 17.27
                      Here is a short video of the behavior - https://www.youtube.com/watch?v=xku-y-_JmAE
                      I had to keep my phone somewhat close to the screen so you could see what it's doing. It cycles like that forever and ever.
                      Any ideas?
                      • grimacelord
                        • Jan 2017
                        • 377
                        Anyone?
                        • grimacelord
                          • Jan 2017
                          • 377
                          Ok. I tested Ve and it reads 114V and the sticker on the back of the panel says it should be 94V. 10v higher than it should be. Also, the TV has stopped flickering like it was and is now without an image at all again.
                          • grimacelord
                            • Jan 2017
                            • 377
                            Also, I tested all of my other voltages AGAIN and they are all within range except for Ve and 5Vsw on the connector leading to the main board. That pin reads 6.93V instead of 5.3V.
                            I'm not sure what to do here, guys. Totally stumped. I don't want to start blindly replacing boards and my customer is growing rather impatient with me, but I can't seem to find a solution. Any (more) help would be appreciated before I'll be forced to abandon the project.
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • SluggerB
                              LG Plasma (PDP50R10101) No picture No sound
                              by SluggerB
                              This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
                              So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
                              Following a YouTube videos...
                              12-03-2022, 09:10 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
                              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:30 PM
