TCL 32S3750 fails to power on
  • impala454
    • Jul 2011
    • 30
    I have a TCL 32S3750 which fails to power on. No standby lights or anything. This started occurring after a storm (Hurricane Harvey!). No visible signs of damage and I think the caps are all mostly flat. Here's a few pics:
    One or two might be a little bulgy? I'm not really sure.
    Main cap seems ok
    I'm not sure where to start, though the main cap reads about 160V.
  • impala454
    • Jul 2011
    • 30
    Re: TCL 32S3750 fails to power on
    Nevermind on this one. I found the whole board for $13 shipped.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      did you confirm that you have your ps/on signal from the main board first?
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • impala454
        • Jul 2011
        • 30
        The whole shebang is one board
        • impala454
          • Jul 2011
          • 30
          Had a second TV in the same apartment with similar symptoms here, if you don't mind taking a look there: https://www.badcaps.net/forum/showth...854#post768854
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            03-31-2024, 02:12 PM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
