marantz LCD 32" FX32LC|| Flickering
    Hi!
    my LCD is flickering from all sources, even when there is no sources - on the blue screen state.
    colors and all other things looks fine.
    im attaching video sample:
    https://drive.google.com/file/d/0B-L...V1M2cwd0E/view
    Re: marantz LCD 32" FX32LC|| Flickering
    looks like your backlights are strobing. this is a ccfl set.
    i would turn the backlight level down first and see if it effects the rate that the strobing is taking place.
    if no change, maybe do a factory reset.
    if still no luck, check to see if the dimming signal is altering or not.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      Thank you for your reply!
      Can you guide me how to turn the backlight level down?
        you should be able to find it in the normal user menu. unfortunately i have never worked on one of these so i don't know the menu layout.
          Is it same option as GAMMA or BRIGHTNESS?
            Here are my options:
            http://imgur.com/a/8lA3V
